× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Readynas 204 mailserver iRedmail
MrtAlways
Hi,
does anyone have a working mailserver with the RN204? If yes, can you please tell me how?
My NAS won't intall the mailserver (iRedmail) at all.
Model: RN204|ReadyNAS204
Message 1 of 13
JennC
NETGEAR Employee Retired
Re: Readynas 204 mailserver iRedmail
Message 2 of 13
MrtAlways
Hi JennC,
Thanks for your repley but it's not the answer I'm looking for.
I want setup a meilserver from available apps with "Iredmail" but I can't instal the app on RN204.
MrtAlways
Message 3 of 13
BrianL2
Hi MrtAlways,
Did you get the iRedmail add-on under the apps tab or the ReadyNAS get apps page?
Kind regards,
BrianL
NETGEAR Community Team
Message 4 of 13
MrtAlways
Hi BrianL
I have tried both, under the apps tab and the ReadyNAS get apps page.
Regards
MrtAlways
Message 5 of 13
BrianL2
Hi MrtAlways,
Could you confirm if you are getting the same behavior when installing other or another app /or add-on? Also, we would like to request the system device logs of your device.
Kind regards,
BrianL
Message 6 of 13
MrtAlways
Hi BrianL,
Yesterday I have tried to install iRedmail from ReadyNAS get apps and I've got the error "Can not install iRedmail" and it wasn't installed.
Today I look again and it is installed. But when I start the app I've got an "internal server error".
Now I can't delete the app.
Hou can I send the systyem logs to you?
And is there a installation guide how to install the app on the ReadyNas like Synology?
MrtAlways
Message 7 of 13
Guru
Message 8 of 13
MrtAlways
Hi BrianL,
I can't install other apps like Plex Media Server.
And I send you the system logs.
Regards
MrtAlways
Message 9 of 13
mdgm-ntgr
It appears the MySQL password is different to what the app was expecting and thus the app failed to install.
Message 10 of 13
MrtAlways
Hi,
I just installed iRedmail. I have no MySQL on my NAS.
If I try to install it I get an error in the system log "System: Cannot install application MySql Server"
I get that error with every app that I try to install. And then i can't uninstall the app.
Mabey the OS system is a little corrupt. Can I do a factory reset witout losing data?
Or is there a better way.
MrtAlways
Message 11 of 13
mdgm-ntgr
MySQL is a dependency for a number of apps.
A factory reset would wipe all your data, so don't do that unless you have a backup of your data.
You could try cleaning things up using SSH (removing the apps including mysql using that) but be aware of the implications of enabling SSH if you want to go down that route.
Message 12 of 13
MrtAlways
Hi,
The only solution for me then is a factory reset. Not something I'm happy about.
Its not my fault that the Nas can't install the apps.
Is there a way that Netgear support has another way to solve this?
MrtAlways
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 3804 views
  • 0 kudos
  • 5 in conversation
Announcements
