× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Readynas 214 Remote Connection without ReadyCloud?
Coolfeather2
Wondering if its possible to remote connect to the nas on windows and linux OS for when I go to tafe this year and need to backup files
Model: RN21400|ReadyNAS 214 Series 4- Bay (Diskless)
Message 1 of 5
FramerV
NETGEAR Employee Retired
Re: Readynas 214 Remote Connection without ReadyCloud?
Hi Coolfeather2,
Welcome to the community.
You could consider using FTP or HTTP over the internet. This will involve opening/forwarding of ports on your firewall.
Message 2 of 5
Sandshark
Sensei
What type of backup, manual or via some backup program?  For manual backups, HTTP or FTP is an option.  If by backup software that can't use either of those, you might want to look at ZeroTier (do a search of the forum) or another VPN solution.
Message 3 of 5
Coolfeather2
Both FTP and HTTP are not secure, I am manually backing up
Message 4 of 5
Guru
The NAS does support FTPS connections from an FTP client (and there is a setting to mandate FTPS) -  so you can make that secure.
ZeroTier, OpenVPN and OwnCloud are all possibilities for remote access.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3081 views
  • 0 kudos
  • 4 in conversation
Announcements
