× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Readynas 312
MaartenProvo
Readynas 312
I have a ReadyNas 312 (v6.9.5) which has been getting slow over the last week. I run:
  • Couchpotato
  • Deluge
  • Plex
  • Resilio Sync
  • Sickrage
  • Home Assistant
I noticed in the logs an error 'systemvolume root usage over 85%  ...' I did some cleaning, using various post on this forum,  but I can't get it below 77%.  Performance has improved but still slow. Any ideas?
Model: RN31200|ReadyNAS 300 Series 2-Bay
Message 1 of 2
Guru
Re: Readynas 312
clamav is taking a lot of space (at least 15% of your OS partition), so perhaps consider whether you really need that.
/usr/lib/local is essentially empty on my system.  The stuff in there must have been installed by apt-get or the apps.
/var/cache is another place to look - it's taking more space on your system than on mine.
/var/lib also is taking up more space than my system.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 508 views
  • 0 kudos
  • 2 in conversation
Announcements
