× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Reply
Readynas 31400 Booting Issue
kalpsr
https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Readynas-31400-Booting-Issue/m-p/22...
replying to this after long time.
I have done factory reset, OS Re-install also after backup.
Also i replaced 2 Tb HDDs with new 4Tb HDDs.
But, issue remains the same.
When I start the NAS first time, it is being stuck at Booting...
Then I do power off and start it again, it will boot normally.
Please provide some other solution.
Message 1 of 18
AnishaA
NETGEAR Moderator
Re: Readynas 31400 Booting Issue
Hello @kalpsr ,
And welcome to the NETGEAR Community! 🙂
Attach the screenshot of the error you are getting and please tell the date of purchase of your NAS device.
Also, download the logs and attach them we will check what causes this issue.'
Have a lovely day,
Anisha A
Netgear Team
Message 2 of 18
kalpsr
please guide how to attach the logs here because it is allowing only image or pdf files for attachments.
purchase date is somewhere in 2020.
Message 3 of 18
Guru
They'll want the entire log zip file. There is some privacy leakage, so it is best to send a private message ( PM) to @AnishaA using the envelope icon in the upper right of the forum page.
Upload the zip to cloud storage (dropbox, google drive, etc), and then put a download link in the PM.
Message 4 of 18
kalpsr
check your PM for details i have sent you.
Message 5 of 18
AnishaA
NETGEAR Moderator
Hello @kalpsr,
From the logs, it seems fine, and could not find any particular error for this issue. Need to investigate the issue deeper.
If you are falling under warranty I would suggest you open a support ticket case.
We will debug the issue and provide a possible solution.
Have a lovely day,
Anisha A
Netgear Team
Message 6 of 18
kalpsr
Warranty is expired for this NAS.
If you can give any other solution then please tell me.
Thanks in advance.
Message 7 of 18
Guru
Does this happen every single time you power up the NAS?
Have you ever seen it happen when you simply restart it (leaving it powered)?
Have you tried running the diagnostics from RAIDar?
Message 8 of 18
kalpsr
As I observed, It is happening when the NAS is powered of without normal shutdown.
No. Issue is not happening when doing normal shutdown and restart.
Ran the test.  Showing not any error.
Message 9 of 18
Guru
@kalpsr wrote:
As I observed, It is happening when the NAS is powered off without normal shutdown.
I don't see anything about how the NAS was shutdown before the failure to boot, and I don't see anything that says whether this happens 100% of the time.
I am asking this: When you power down the NAS with the preferred shutdown, does it always fail to fully boot when you start it up again?  Or does it sometimes boot normally?
Message 10 of 18
kalpsr
Yes always, with Booting... message only.
Then i will have to power off manually by pressing power button.
Once in a while it boots normally.
Message 11 of 18
Guru
Also, can you connect the NAS hdmi port to a monitor before you boot it up?  There might be some clues on the screen if you do that.
Message 12 of 18
kalpsr
NAS Display when no boot
HDMI Display when no boot
HMDI Display when it boots successfully.
Message 13 of 18
Guru
So no prompt at all on the HDMI screen, and no disk activity lights lit when the problem occurs?
Message 14 of 18
kalpsr
-> Only one cursor blinks.
-> All Disk Led off.
Message 15 of 18
Guru
Definitely an odd problem.  I'm tagging @Sandshark to get his thoughts.
I'm guessing that the system isn't getting past POST (though it is odd that the LCD shows "booting" if that is the case).
When you power down the system, is it still connected to mains power?  Or is that turned off?   If it is connected to mains power, have you tried unplugging it for a while (~15 minutes or so), and then see if it boots normally?
Message 16 of 18
Sandshark
Sensei
There will be no prompt, but you should see some boot activity.  You see nothing at all?
Message 17 of 18
kalpsr
-> Yes. remains connected to power.
-> Tried that also. But same issue at first boot.
-> No. Just one cursor blinking.
But when it boots successfully, it will display messages like booting kernal..etc. (as per third snap)
Message 18 of 18
Top Contributors
Discussion stats
  • 17 replies
  • 377 views
  • 0 kudos
  • 4 in conversation
Announcements
