Orbi WiFi 7 RBE973
Reply
Readynas 526X - Mapped drive slow to connect then works fine
ryankoenigdsi
Model: ReadyNAS 526X
Firmware: 6.9.2
Windows Server 2016 with Windows 7 and 10 workstations
Issue: I have the ReadyNAS mapped to a drive through a GP, and all users have a long initial connection to the NAS. Once they connect, browsing is fine. After about 10 minutes, this behavior returns. Disk spin down is turned off.
What steps or information is needed to help troubleshoot this?
Model: RN526X| ReadyNAS 526X 6-Bay with up to 60TB total storage
Message 1 of 7
mdgm-ntgr
NETGEAR Employee Retired
Re: Readynas 526X - Mapped drive slow to connect then works fine
Which services are you running?
Any apps?
How many users roughly do you have?
Message 2 of 7
ryankoenigdsi
Just using it as a file share, no services or apps running from the ReadyNAS.
We have ~20 people with it mapped.
Message 3 of 7
mdgm-ntgr
Is the NAS in the same workgroup / domain as your workstations?
Message 4 of 7
ryankoenigdsi
It was just "plug and play"ed on installation. Would this be causing the lag at start, where the user is trying to get authentication to the NAS? Where would these settings be to check this?
Thanks for your help
Message 5 of 7
ryankoenigdsi
Just following up on this. Where would these settings be, to check?
Thanks,
Ryan
Message 6 of 7
Guru
On the NAS it is under accounts->authentication in the web ui.
On a Windows PC, right click on "This PC" or "My Computer" and select properties.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1549 views
  • 0 kudos
  • 3 in conversation
Announcements
