× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Readynas Duo V2: Can't access Dashboard
Beginnerx
Follower
I have a Readynas Duo V2 and for some days I can't access the dashboard. I can access the shares on the device. Raidar sees the device but no access to the dashboard; not when directly connected to my PC or when connection via router.
Windows network control says: 'the device doesn't accept connection on port https'
Same issue as #24626114
I am using Win 10, Edge and RAIDiator 5.3.7 which I will update to 5.3.12
Message 1 of 3
FramerV
NETGEAR Employee Retired
Re: Readynas Duo V2: Can't access Dashboard
Hi Beginnerx,
Welcome to the community.
Does this happen on other devices on the network?
Have you tried other browsers? Also, check if you have anti-virus or malware protection enabled. Try to put the ReadyNAS IP on the white list (if applicable). Clearing the cache of the browser might also help.
Message 2 of 3
JennC
Hi Beginnerx,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1648 views
  • 0 kudos
  • 3 in conversation
Announcements
