- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Readynas NV+ SLOW TRANSFER SPEED
- Mark as New
- Bookmark
- Subscribe
- Permalink
ReadyNAS NV+
RAIDiator 4.1.15
4x 1TB WD Green
Raid 5
PC is gigbit, but my transfer speed maxes out at 12MB/sec. I've tried connecting directly to the NAS, and no change in speed. Jumbo frames is diabled on pc and nas. No smart+ errors. Cables are tested and good. Any other suggestions? Just used NAS Tester and the top write speed was under 11MB/sec.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Readynas NV+ SLOW TRANSFER SPEED
Is the NAS also showing 1 gigabit for the ethernet connection?
FWIW, this is slower than usual, but you won't get anywhere close to gigabit speed with an NV+. You should be seeing something around 20 MB/s.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
My PC and ReadyNAS show gigabit when I go into my modem. I've also tried connecting directly to the readynas with an ethernet cable (cat6, brand new).
- Mark as New
- Bookmark
- Subscribe
- Permalink
No backup jobs, and no addons. I transfer using CIFS. I've also used NAStester and had the same results. I've tried with jumo frames enabled, and disabled on both my pc and readynas.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you use this guide to check block size and 4K alignment? http://www.rnasguide.com/2011/06/22/why-you-might-want-to-factory-reset-a-sparc-readynas/
NAStester uses CIFS btw.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Normally lack of 4K alignment hurts performance with 2 TB drives, not the 1 TB models you are using. Though it might impact performance with newer 1 TB disk models too - it depends on how they are constructed. The block size would only be an issue if the volume was created using RAIDiator 3.x firmware.
But if the volume is very old, you might find that a factory reset will improve the performance anyway.
Another place to look is at the network stats. If you are seeing ethernet errors or dropped packets, that is a clue that the issue is network related.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Astiran wrote:
I'm using raid 5,would you recommend a different raid setup?
The NV+ actually uses RAID4 (dedicated parity disk) - the GUI does call it RAID5 though.
RAID5/XRAID is a good setup.
@Astiran wrote:
...the ethernet port was fried by the lightning. Swapped the drives to the new readynas and I didn't lose any data.
I'm glad you didn't. As I'm sure you know, you easily could have. Likely the NIC card acted like a fuse, and protected the drives.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I didn't realize that it doesn't actually use raid 5. I do need the redundancy to protect my data, but is there a difference between the raid 5 and xraid? Or is it just a different name?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It has the same redundancy as RAID-5. The only difference is the organization of the parity blocks. RAID-5 distributes the parity blocks over all the disks, RAID-4 puts them all on a dedicated parity disk. Distributing the blocks evens out the I/O across the disks. Your NV+ has hardware acceleration for RAID, and I think that is why it uses RAID-4.
Newer NAS (NV+ v2, ultra, pro, all OS 6 NAS) use RAID-5.
XRAID is built on top of standard RAID. In your NAS it will convert from single disk->raid 1->raid 4 as you add drives. If you upgrade all four drives, it will also expand the volume automatically. As you likely know, the NV+ can't handle drives larger than 2 TB.
On newer NAS, it can also handle drives of different sizes, and (if you want it) dual redundancy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Found this in my partition logs.
WARNING: GPT (GUID Partition Table) detected on '/dev/hde'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/md0 doesn't contain a valid partition table
Disk /dev/md1 doesn't contain a valid partition table
Disk /dev/md2 doesn't contain a valid partition table
Disk /dev/hdc: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 fd Linux raid autodetect
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 5144607 524288 fd Linux raid autodetect
Partition 2 does not end on cylinder boundary.
/dev/hdc3 5144608 1953508815 974182104 fd Linux raid autodetect
Partition 3 does not end on cylinder boundary.
Disk /dev/hde: 1000.2 GB, 1000204886016 bytes
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is normal, so don't worry about it. I don't know why Netgear continues to run fdisk.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still no luck. Backed up all of my data, did a complete reset, formatted to raid 5, still getting about 10MB/s write speeds. I'm thinking when I'm in the market for a new nas I might just avoid netgear. I used to have a WD Sharespace and it was faster than this, even though it was quite a bit older.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your NV+ v1's hardware design goes back to 2006 - I don't think WD was building NAS back then. It's been end-of-life for over 5 years. A new ReadyNAS can delivers 50-100+ MB/sec on a gigabit network (depending on which model you purchase).
That said, 10 MB/sec is slower than it should be. Did you look at the ethernet stats for packet loss?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had a WD Sharespace back around 2008 or maybe a year or 2 later. I just got the ReadyNAS in about 2012 or 2013. I'm looking at the network errors popup from frontview and:
Auto-negotiation 0
Bad packets 0
Disconnect 0
False carrier 0
Idle errors 0
Link failures 0
Receive errors 0
Symbol errors 0
VLAN tags 1517
TCP Retransmits 79
Unrecovered TCP Retransmits 33
- Mark as New
- Bookmark
- Subscribe
- Permalink
The NV+ v2 was launched in Nov 2011, so you must have purchased right around the time the retail channels were getting rid of inventory.
It's unusual to see vlan tags. Do you have vlans set up on your network?
The TCP errors aren't that unusual, though if there weren't a lot of packets sent they could be a clue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm currently transferring everything back to the NAS now so there is a lot of data going through. I don't have any vlans setup at all, at the option in frontview is UNchecked as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still, the NAS is seeing packets come in that have VLAN tags. They have to be coming from somewhere...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any suggestions on where I should start looking??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have managed ethernet switches on your network?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Odd. Is the “xfinitywifi" network running?
- Mark as New
- Bookmark
- Subscribe
- Permalink
