Orbi WiFi 7 RBE973
Reply
Readynas PRO OS6 loses network connection
Harold825
Hi ,
I have a Readynas PRO6 with OS6 (6.10.3) installed.
every once in a while the Readynas loses network connection (Raidar , Putty , windows explorer). Sometimes it happens after 30+ days , sometimes after several hours.
It happens to both network connections (although not always at the same time it seems).
Switching the box off with the front power switch only works at 50% of the times and always takes a long time. Switching off and restarting by keeping the button pressed for 5 seconds always works and restarts the network connection as well.
The diagnostics from Raidar show: (assembled from several files) :
Successfully completed diagnostics
System
No errors found.
Logs
2020-04-14 03:37:01: general protection fault: 0000 [#3] SMP
2020-04-14 03:37:01: RIP [ ] free_extent_buffer+0xb/0x7a
2020-04-13 22:42:17: general protection fault: 0000 [#1] SMP
2020-04-13 22:42:17: RIP [ ] __fget_light+0x42/0x59
2020-04-13 22:42:17: general protection fault: 0000 [#2] SMP
2020-04-12 14:13:46: general protection fault: 0000 [#1] SMP
2020-04-12 14:13:46: RIP [ ] __fget_light+0x42/0x59
2020-04-12 14:13:46: general protection fault: 0000 [#2] SMP
2020-04-11 09:11:06: general protection fault: 0000 [#1] SMP
2020-04-11 09:11:06: RIP [ ] __fget_light+0x42/0x59
2020-04-11 09:11:06: general protection fault: 0000 [#2] SMP
2020-04-09 13:02:37: general protection fault: 0000 [#1] SMP
2020-04-09 13:02:37: RIP [ ] __fget_light+0x42/0x59
2020-04-09 13:02:37: general protection fault: 0000 [#2] SMP
2020-04-09 05:21:53: general protection fault: 0000 [#1] SMP
2020-04-09 05:21:53: RIP [ ] __fget_light+0x42/0x59
2020-04-09 05:21:53: general protection fault: 0000 [#2] SMP
2020-04-06 13:53:12: BUG: unable to handle kernel NULL pointer dereference at 0000000000000030
2020-04-06 13:32:03: general protection fault: 0000 [#3] SMP
2020-04-06 13:32:03: RIP [ ] filp_close+0x9/0x6f
2020-04-06 13:32:02: general protection fault: 0000 [#2] SMP
2020-04-06 13:32:02: RIP [ ] __fget_light+0x42/0x59
2020-04-06 13:24:21: general protection fault: 0000 [#1] SMP
2020-04-06 13:24:21: RIP [ ] poll_freewait+0x49/0x90
I did a memory test and that all seemed fine ...
Most of the time the unit stops when it is idle , in the night or when not accessed .
Has anyone seen this behaviour before and can maybe point me in the right direction to correct this ?
Thanks !!
Harold
Model: ReadyNAS-OS6|
Message 1 of 22
Accepted Solutions
Harold825
Re: Readynas PRO OS6 loses network connection
after several days without any hickups I hope it's safe to say it is solved .
I think the topic can be closed . The trouble must have originated from the Sickbeard app.
Thanks for the support @StephenB  , @Sandshark  !
Message 21 of 22
All Replies
Guru
How much memory is installed?
Message 2 of 22
Harold825
Hi, thanks for the quick reaction !
It has 2GB (2x1) Memory and I upgraded the CPU as well (Core2DUO) but not sure which, long time ago...
reg,
Harold
Message 3 of 22
Guru
That should be enough.
Free_extent_buffer is part of btrfs, so the most recent one is rather concerning.
You should certainly make sure you have an up to date backup.  Have you downloaded and looked through the full log zip file?
Also, generally you should run multiple passes of the memory test.  Did you do that, or only run one pass?
Message 4 of 22
Harold825
Hi Stephen,
I ran the memory pass 5 times, about an hour . I understood that should be OK.
The strange thing is that the problem seems to change a bit, after the the last OS upgrade for a while it seeme OK. I recently had a run of more than 30days without any problems. The last couple of days has become worse although I did not change anything AFAIK.
After every incident I downloaded the logs but I have no idea where to look or what to look for .
Meanwhile I had another stop:
2020-04-14 16:35:18: RIP [ ] __fget_light+0x42/0x59
2020-04-14 16:35:18: general protection fault: 0000 [#4] SMP
2020-04-14 16:35:17: general protection fault: 0000 [#3] SMP
2020-04-14 16:35:14: general protection fault: 0000 [#2] SMP
2020-04-14 16:35:14: RIP [ ] filp_close+0x9/0x6f
2020-04-14 16:35:13: general protection fault: 0000 [#1] SMP
2020-04-14 16:35:13: RIP [ ] filp_close+0x9/0x6f
Today I cleaned out the unit of accumulated dust, never hurts .
When you asked about the memory I needed to check and restarted with a DDR2 strip not seated properly which resulted in the unit currently Resynching...
 Any ideas what direction to search for an answer ?
I could put the disks in an Ultra6 that I have as a backup unit (same OS) or wouldn't that work ?
Thanks for your help
Harold
Message 5 of 22
Guru
5 passes should be enough.  I am wondering if you actually were running with 1 GB (given the reseating).  But that shouldn't have triggered a resync.
That would work.
Message 6 of 22
Sandshark
Sensei
Trouble with the power button and NIC together is usually a sign of a failing power supply.  Both of those use the +5VSB (+5 volt standby) power.  Since that stay on all the time, even when the NAS is "off" (except via the rear switch or unplugging), so the switch and WoL will work, it's often the first to go.
Message 7 of 22
Harold825
thanks Sandshark,
Don't think the powerbutton is a problem, actually the unit sometime does not shut down by the frontpage command and the WOL is not reliable either (same goes for the restart).
The powerbutton is the last resort to get the unit to do what I want ..
H
Message 8 of 22
Harold825
The problem with the memory was because I took them out to check the sizes. I then did not put it in propperly.
When rebooring the unit stopped  with "Readynas" showing on the display. I tried to get into the boot menu before finding the memory problem so once everything was in place the unit booted as usual BUT started resynching.
Now at 32% so hopefully it will be finished in the morning (CET !)
actually I also renewed the mainboard battery as this was completely empty. I did not lose any settings by doing this actually. So it seems this doesnt affect things ?
Would there be an advantage in upgrading memory to 4 or 8 GB ?
I could acquire Kingston KTH-MLG4/8G cheap ...
Message 9 of 22
Sandshark
Sensei
While the button may not be "a problem", it sounds like a symptom, and my original statement about the possibility of a failing power supply still holds.  Your symptoms are quite common of that.
You may see a slight improvement with an upgrade to 4GB RAM.  But unless you are doing some major transcoding or other intensive operations, I doubt you will see much additionally going from 4 to 8.  Plus, the right kind of 4GB sticks are not cheap.  The ones you listed won't work.  They are ECC Registered, and I think high density as well (Kingston doesn't list the architecture, but the number of chips per stick makes me think it is).  The Pro needs non-ECC, unregistered, low density (2Rx8) memory, and there was little call for that in a 4GB size back when DDR2 memory was commonly used..
The battery only keeps the real-time clock running.  Without one, you will usually see the first log entry using a Jan 1 (I forget the year) date, as it's before the NNTP time sync occurs.
Message 10 of 22
Harold825
I will start looking for a replacement powersupply , as the unit is quite old it wouldn't hurt anyway.
Just to understand a bit better, wouldn't a problem occur more frequently when the Nas is under load ?
Mostly it stops during the night ...  Using the two network connections did help sometimes when only one connection went down.
Do you think the file system problems as indicated by Stephen are also created by this ?
A line of thought was a problem with memory, is there another way to see if both strips are recognized ? Could it be that one is placed but not recognized so that the unit is actually running on 1GB iso 2GB ?
Message 11 of 22
Guru
Yes, I think the file system error was caused by this (note one of the recurring general protection faults happened right before the error).
You can enable ssh and enter
# cat /proc/meminfo | grep MemTotal
This will be slightly less than the physical memory.  I see 3937028 KB when I run this on my RN526x (which has 4 GB of RAM).
There are background activities that can run off-hours (Antivirus Updates, polling for hot fixes, BTRFS stuff).
FWIW, losing the network connection is just one symptom.  The general protection faults can disrupt a lot of different processes.
@Sandshark: Is it possible that something might be going on with the CPU that could be checked?  It was upgraded (though some time ago).
Message 12 of 22
Harold825
I will start to look for a new Power Supply, does anybody have experience with a corsair SF450 ?
@StephenB @Sandshark thank you for your support , It gives confidence to keep the systems alive. Much appreciated !
If there is something else I can check or do please let me know. In due course I will mention the results (It may take a while)
Harold
Message 13 of 22
Sandshark
Sensei
Before you invest in a new supply, you can use a standard ATX supply externally.  If that fixes the button issue, then you probably don't need to run it till you see the NIC issue.  But if you want to, just make sure you seal the gaps in the back where the cable comes through with masking tape or something similar so airflow is as good as it can be.  Maybe seal the opening for the power supply fan, to, since it won't be running and air could come in instead of out.
I have seen others post that the Corsair is a good choice.  Unlike a lot of others, it has the necessary three Molex connectors.  And the modularity makes it easy to eliminate csaables you don't need.
Message 14 of 22
Harold825
Hi
well I didn't recognize the button as the issue actually (I never switched it off), trouble is that the unit becomes unresponsive once in a while and it can't be accessed from the network then. pushing the power switch will always start the shutdown but most of the time it says shutting down and then nothing happens ...
I can then just push the button for 5seconds and it shuts down straight away ! After that I can restart and network connection is active again ...
Shutting down from Raidar mostly gives the same problem.
Message 15 of 22
Guru
I think the key here is that the button itself is working (the NAS is detecting that is is pressed).
Message 16 of 22
Harold825
This would mean it is not necessarily a PSU problem but could also be a software issue ?
Message 17 of 22
Guru
I certainly think the PSU is a possibility.  But I think the jury is out on whether it's that or something else (hardware or software).
If you have an ATX supply around, then I'd go with @Sandshark's suggest to try that out and see if anything changes.
Message 18 of 22
Sandshark
Sensei
That is a different kind of button problem that I toght you were talking about, and does sound like more of a software issue than a hardware (including power supply) one, though it doesn't eliminate a hardware issue.
Message 19 of 22
Harold825
Following Sandsharks remark I investigated the software side a bit more.
One of the errors shown in the diagnistics Log ( RIP [ ] filp_close+0x9/0x6f ) seems directly connected to the shutdown or restart command.
To me this seemed that something is preventing the shutdown so I decided to uninstall the apps one at a time.
The first , Sickrage (by Poussin) immediately threw me out of frontview when I uninstalled !
After a restart now at least the shutdown AND the WOL seem to work again .
Fingers crossed that there was something in that app that caused the trouble ...
To be continued
Harold
Message 20 of 22
Harold825
Message 21 of 22
Guru
Glad to hear that!
Message 22 of 22
Top Contributors
Discussion stats
  • 21 replies
  • 3406 views
  • 0 kudos
  • 3 in conversation
Announcements
