- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Readynas Pro 6 - Err Used disks Check RAIDar
- Mark as New
- Bookmark
- Subscribe
- Permalink
This problem occurred recently when i swith it on after standart shutdown (not power outage).
Is it possible to do something without factory reset?
I am not sure about OS reinstall on legacy models running OS6, but if it can help, i may try.
TNX!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
If it were my system, I'd test the disks with vendor tools in a windows PC (seatools for seagate, lifeguard for western digital). Replace any that fail (or which have more than 50 reallocated+pending sectors).
Then do a factory reset with all disks in place. Reconfigure the NAS and restore the data from the backup.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Readynas Pro 6 - Err Used disks Check RAIDar
You can use the OS reinstall from the boot menu. I don't know if that will fix it, but it is worth a try.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for answer.
I have try to make OS Reinstall, device reboot and stuck at "Booting... Checking root FS" (more then 1 hour).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had a similar experience yesterday with my Pro 4.
Powering down the NAS and using Reinstall OS from the Boot Menu again then worked successfully
- Mark as New
- Bookmark
- Subscribe
- Permalink
How long you waited for checking root FS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cannot remember but it should only be a few minutes
- Mark as New
- Bookmark
- Subscribe
- Permalink
telnet in Tech mode:
login: root Password: # start_raids -v Found new array data-0 [c4b4e8c3:c42179a2:fed11c6a:c2a4af1] Found new array 1 [6830d0fa:a6ede353:6e4678e:be7d83] Found new array 0 [f2fc4dc:133c8eb9:4f907524:fdab7081] Checking array 0 uuid: f2fc4dc:133c8eb9:4f907524:fdab7081 hostid: 33ea412f raid_disks: 6 ctime: 1497865502 layout: 0 size: 8380416 chunk_size: 4247053 Checking array 1 uuid: 6830d0fa:a6ede353:6e4678e:be7d83 hostid: 33ea412f raid_disks: 6 ctime: 1497865503 layout: 2 size: 1047424 chunk_size: 4247605 Checking array data-0 uuid: c4b4e8c3:c42179a2:fed11c6a:c2a4af1 hostid: 33ea412f raid_disks: 6 ctime: 1497865529 layout: 2 size: 3897329664 chunk_size: 4247677 Setting array data-0 to run Run: /sbin/mdadm -A -R -f --auto=md /dev/md/0 /dev/sdf1 /dev/sde1 /dev/sdd1 /dev /sdc1 /dev/sdb1 /dev/sda1 mdadm: /dev/md/0 has been started with 6 drives. Run: /sbin/mdadm -A -R -f --auto=md /dev/md/1 /dev/sdf2 /dev/sde2 /dev/sdd2 /dev /sdc2 /dev/sdb2 /dev/sda2 mdadm: /dev/md/1 has been started with 6 drives. Run: /sbin/mdadm -A -R -f --auto=md /dev/md/data-0 /dev/sdf3 /dev/sde3 /dev/sdd3 /dev/sdc3 /dev/sdb3 /dev/sda3 mdadm: /dev/md/data-0 has been started with 6 drives. Found 0 fstab name matches, and 0 fstab mountpt matches mount: mounting LABEL=33ea412f:data on /data failed: No such file or directory /bin/sh: /sbin/btrfs: not found # btrfs check --repair /dev/md0 enabling repair mode repair mode will force to clear out log tree, Are you sure? [y/N]: y Checking filesystem on /dev/md0 UUID: ba959f04-d0d7-4cf6-9c3b-56b945f4599c checking extents ref mismatch on [1003638784 8192] extent item 1, found 0 attempting to repair backref discrepency for bytenr 1003638784 Ref doesn't match the record start and is compressed, please take a btrfs-image of this file system and send it to a btrfs developer so they can complete this f unctionality for bytenr 434857640905023360 failed to repair damaged filesystem, aborting # btrfs filesystem show /dev/md0 Label: '33ea412f:root' uuid: ba959f04-d0d7-4cf6-9c3b-56b945f4599c Total devices 1 FS bytes used 944.80MiB devid 1 size 4.00GiB used 1.64GiB path /dev/md0 # mount /dev/md0 /sysroot segmentation fault # btrfs filesystem show /dev/md127 Label: '33ea412f:data' uuid: 436f1a9d-4eff-4db1-8b1a-c4da4f4230e6 Total devices 1 FS bytes used 4.80TiB devid 1 size 9.07TiB used 5.46TiB path /dev/md127 # mount /dev/md127 /mnt/ # ls -la /mnt drwxrwxrwx 1 222 Oct 4 17:38 . drwxr-xr-x 20 460 Dec 4 14:09 .. drwxrwxrwx 1 158 Oct 4 17:38 ._share drwxrwxr-x 1 230 Dec 4 12:57 .apps drwxrwxrwx 1 0 Jul 9 13:06 .purge drwxr-xr-x 1 0 Jun 19 09:56 .timemachine drwxrwxrwx 1 0 Jun 19 09:45 .vault drwxrwxrwx 1 1006 Jul 10 19:46 camfc drwxrwxrwx 1 1006 Jul 10 19:41 camfr drwxr-xr-x 1 12 Jun 19 09:45 home drwxrwxrwx 1 106 Jul 17 14:20 rsyslog drwxrwxrwx 1 9434 Nov 28 20:24 ?????????? drwxrwxrwx 1 78 Oct 2 10:27 ??????????? drwxrwxrwx 1 660 Jul 20 19:20 ??????
as far as i understand 4gb roos FS internal flash is broken (my NAS have about 6 years uptime). is it true? how to solve this problem? is it possible to boot from flash in USB port and use it for root FS?
by the way, sometimes, my NAS starting ok, but frozen in 1-2mins. it is impossible to do something when NAS starts ok.
TNX for answers!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't think your flash is damaged - if it were, you'd likely have failed to boot into tech support mode. It's more likely that the OS partition on the disks is damaged (along with the data volume's file system). /dev/md0 is the OS partition on the disks.
You can test this by installing a scratch disk in the NAS by itself, and attempt to do a factory reset from the boot menu. If that works, then problem is with the disks, not the flash.
- Mark as New
- Bookmark
- Subscribe
- Permalink
exactly! you are right.
what should I do further?
I do a backup, of course. and... and what's next? my disks have 4-6 years uptime... I have to buy new disks?
and why system corrupt so heavy? volume was RAID5. Upon failure of a single drive, subsequent reads can be calculated from the distributed parity such that no data is lost.
- Mark as New
- Bookmark
- Subscribe
- Permalink
