× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Readynas Pro 6 - Err Used disks Check RAIDar
jijishpt
Follower
Hi,
I am using 3 HDD in RN31400, replaced 1 HDD which is not working, now getting message Used Disks Check RAIDar. tryed OSreinstall from boot menu but getting same message. Is there any process to rebuild the raid without data loss.
Model: RN31400|ReadyNAS 300 Series 4-Bay
Message 1 of 2
Guru
Re: Readynas Pro 6 - Err Used disks Check RAIDar
Did you try powering downm removing the new hard drive, and booting up without it?
If that works, then hot-insert the new drive (with the NAS running).  You'll probably need to format it from the volume page before the system will add it to your current volume.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 505 views
  • 0 kudos
  • 2 in conversation
Announcements
