- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Readynas Replicate
- Mark as New
- Bookmark
- Subscribe
- Permalink
Readynas Replicate
I have two devices, one at home and one at a remote location and the home NAS backups up to the remote NAS on a schedule. All works fine but I have a lot of history folders within each of the backup folders. I originaly made the mistake of setting them up as being kept for eternity, I have now limited the number of versions. My question is with the old folders be deleted over time or do I need to do it manually and also if I delete them now what impact will it have? I'm runnign out of space on the remote NAS hence the question although the required backup storage is well within the stored capacity it's just the versions that are padding it out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Readynas Replicate
I'm assuming you're using ReadyNAS Replicate, is that correct?
Afaik, during next run of the job, if successful, it will rotate (and flush) the old occurrences. Can you manually start the job to trigger that? Or do you fear not having enough space for a new occurrence?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi jak0lantash
Thanks, yes I'm using readyreplicate, it's set for daily back up so will automatically run again tonight but I've still got a backlog of previous folders. Can I just delete these (or least early ones)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you want, you can run the job manually from the Replicate website.
