- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Readynas duo never gets ready
- Mark as New
- Bookmark
- Subscribe
- Permalink
Trying to start up my (old) Readynas DUO but it will never get ready. When I starting the device the lamp is blinking, and will never stop. I have been waiting for more than 24 hours. I have also tried to do a OS backup (holding resetbuttom for 5 sek, waiting for the disklamps to flash) No action!
I have also tried to to a full factory reset (holding reset buttom for ca 25 sek, wating for the disklaps flashing 2 times)
After that I also have waited more than 12 hours.
What is wrong?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Jobarez wrote:
Yes, that is working! I can find the nas with "no disks found"
Great. That suggests that the startup issue might be related to the disks.
So perhaps test the disks in a windows PC with vendor diags (lifeguard for wdc, seatools for seagate). Or try starting the NAS with only one of the disks installed.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Readynas duo never gets ready
Are you seeing one of these LED patterns?
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by a 1 second delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 – Vendor mismatch
2 – No disks detected
3 – Bad contents on root partition of disks
4 – Flash error
5 – Unsupported RAID configuration
Also try installing RAIDar on a PC - if the NAS is on the network it can report status.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When the nas is booting up its flashing fast in about 2-3 minutes after that the flashing changes to a slightly slover pace. But no, patterns what I can see.
I'm using mac os 10.10, Cant find then nas on Raidar. Have no PC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your mac is a PC, just running a different OS.
You'll find RAIDar for mac here: http://kb.netgear.com/app/answers/detail/a_id/20684/~/readynas-downloads#raidar?cid=wmt_netgear_orga...
Is there any data on the Duo that you care about?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Allright!
I have RAIDar 6.1 installed, and cant se the NAS. (I am on the same network)
I do not care about whats on the NAS ( I havel already tried/done a facory reset)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try removing the disks and looking again with RAIDar. If the duo is functional, RAIDar should find it and report a "no disks" status.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks!
I tryed to start the NAS with one disk and it worked, I got some warning about the disk so I will change the discs to new ones. Thanks alot for guidning me to the sulution!
