- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Readynas rnd2000 v2 firmware upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
After a recent power failure (despie being on UPS) my ReadyNAS no longer works.
Both green drive leds are lit & the working(CPU..?) led flashes occasionally.
The Blue power led gives 4 slow flashes.
Raidiar shows - File System Check. and stays that way for hours.
Pressing the power switch has no effect.
I have read numerous posts & connected direct setting the PC to static IP 192.168.168.5
I have reinstalled OS - by holding reset & powering up until 1st flash of drive leds.
Still no fix.
Any assistance gratefully received..!!
Rob
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
That disk has failed very badly. With that high an error count presumably there would have been some SMART errors occurring for quite some time.
Replacing that disk with a new disk would certainly be worth a try.
Do you have a backup? Is that up to date?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Readynas rnd2000 v2 firmware upgrade
Are you sure you have a v2? Your profile shows that you bought a v1 just over 5 years ago now.
Please see How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
Mine is definately a Version 1.....
but the model number sticker shows RND2000 v2
(I did try to make that plain in the post, but I had to try several times...seems the final post that eventually went was missing that bit)
- Mark as New
- Bookmark
- Subscribe
- Permalink
One of your disks (probably disk 1) is bad
It has a current pending sector count of 24 and an ATA error count of 18970
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have to admit - that doesnt mean much to me.
So if I replace that disk - it should fix the problem..??
I thought running raid - it would function with one disk down..??
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, I have no backups.
The whole idea of having the Raid server was to provide safe (backedup in the array) storage.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your help so far - I will drive down to town today16th Feb & get another Hard Drive.
That will mean I wont be back until later on 17th Feb.
Will let you know how it goes..
- Mark as New
- Bookmark
- Subscribe
- Permalink
I understand that after replacing the bad disk the system is now working fine and you are proceeding to do a backup. It's advisable to backup your data regularly. RAID provides redundancy and is very useful, but it's not a replacement for backing up your data. Don't store important data on just the one device, no matter what that device is.
