× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Readynas v+ (Help) How to switch between other drive
ash004
Well Basically, when i configure the ready nas it take both drive and use them together, but is there a way where i can raid drive ? i mean use the drive differently? like by example if i got 2 terabyte space, How can i switch data from one drive to another is this Possible or? Not, wanted to know because will be Implementing soon the machine into company
Message 1 of 3
Guru
Re: Readynas v+ (Help) How to switch between other drive
By default the system uses XRAID, which would be RAID-1 with 2 disks, and RAID-5 with 3 or more. With these raid modes, your data is spread across both drives.
If during the original install, you tell the system to use FLEXRAID, then you can set up other raid configurations manually, including keeping the disks independent. This is described in the manual.
Do you know if you are working with a v1 or a v2? Use the guide here: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
DON'T just look at the label...
Message 2 of 3
ash004
Ah oki then its xraid and i believe its done automatically ty
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2805 views
  • 0 kudos
  • 2 in conversation
Announcements
