Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Reasonable backup differences?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-10-15
01:42 AM
2013-10-15
01:42 AM
I've just done a complete set of onsite and offsite backups. The existence of the .AppleDouble files and a couple of other special Mac file types has confounded my verification of backups. I'd like a quick sanity check if possible.
On a NAS directory containing ~700 GB, ~86k files, which consists of mostly media, .mp3, mkv and .jpg files are the following differences between the original NAS and backup directory cause for any suspicion that my rsync backups have missed files:
I've used du -sh when logged into a local Mac on the network
-Original directory on NAS: 659 GB
-Same directory backed up on USB drive: 702 GB
~40 GB is a pretty big difference, obviously
I also get different counts of files by about 100 files using "find /directory -type f | wc"
I'm very keen on any general advise for the verification of backups. This should be easier...
Message 1 of 10
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-10-15
03:37 AM
2013-10-15
03:37 AM
Re: Reasonable backup differences?
The USB drive has more data usage. Does it also have the larger file counts?
Also, is the option to delete files not found on the source turned on?
Message 2 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-10-15
08:51 AM
2013-10-15
08:51 AM
^ Thanks. The USB backup drive indeed has the larger file count and space used. I do have the option selected to delete files not on source. However, this was a first time (new BU drives) back up process so this was a full backup. As such I expected a very high correspondence between sizes and file counts.
Message 3 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-10-15
09:17 AM
2013-10-15
09:17 AM
I'd expect that also.
Sizes (as stored on the disk) certainly might differ if the USB drive is not formatted as ext, or if the cluster size is different. However, 6% is more than I'd expect.
The extra files are something else again. Perhaps write the complete directory list to a file, and diff them???
Message 4 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-10-15
11:30 AM
2013-10-15
11:30 AM
Thanks!
External USB disks are always formatted as ext3. Yes 6% or so bigger was my concern. In another backed up directory, my single largest, 3+ TB, mostly .mkv files, the file counts and space used are identical, using du and find /directory -type f | wc.
I've tried diff but the output is perhaps 10 of thousands of lines and most it just list differences in those darn .AppleDouble files/directories...
What would be ideal would be a unix command to list all files in all original directories but not in the backup directory but exclude all files in all .AppleDouble directories in the original directories... Might have to post that request on a unix forum somewhere as I'm pretty much a noob...
Message 5 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-10-15
02:17 PM
2013-10-15
02:17 PM
Add this to the end of the diff command
Can't remember if you need quotes around .AppleDouble or not
| grep -v .AppleDouble
Message 6 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-10-15
02:21 PM
2013-10-15
02:21 PM
swamp2 wrote: I've tried diff but the output is perhaps 10 of thousands of lines and most it just list differences in those darn .AppleDouble files/directories...
Don't use diff, use a visual comparison program that shows the files side-by-side with differences highlighted. WinMerge is nice if you can run Windows apps; I don't know what's good for Mac.
swamp2 wrote: What would be ideal would be a unix command to list all files in all original directories but not in the backup directory but exclude all files in all .AppleDouble directories in the original directories... Might have to post that request on a unix forum somewhere as I'm pretty much a noob...
Try this (which I haven't tested). It will create a file called "original.txt" at the root of your original directory, and a file called "backup.txt" in the root of your backup directory. Each file will contain a list of all the subdirectories and files in those directories, with relative pathnames and sorted for easy comparison:
cd /original_directory
find . | sort > original.txt
cd /backup_directory
find . | sort > backup.txt
Then use your visual differencing tool to compare /original_directory/original.txt with /backup_directory/backup.txt.
Message 7 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-10-15
06:31 PM
2013-10-15
06:31 PM
mdgm wrote: Add this to the end of the diff command
This is fantastic, thanks so much. It seems to work without quotes and is now extremely close to what I need. Can I bug you for one more syntax help and clarify function?
diff -qr /dir1 /dir2 | sort | grep -v .AppleDouble
Will recursively compare dir1 and dir2. It will find all items that are present in any directory in dir1 that is not also in the same location in dir2. It will exclude all results in directories in dir1 containing the text ".AppleDouble". Correct?
Is it easy to exclude an additional directories based on the presense of a different string. I basically need a logical OR in the grep.
Message 8 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-10-15
06:33 PM
2013-10-15
06:33 PM
Well an easy method would be to do another grep. Alternatively I think \| is what you need for OR
Message 9 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-10-20
01:48 PM
2013-10-20
01:48 PM
Thanks again all. This has been a great help in verifying my backups.
Message 10 of 10
