Orbi WiFi 7 RBE973
Reply
Recreating Shares
psxman_uk1
Recreating Shares
I have an issue with the 104 where one of my hds has died i am waiting on a replacement in the mean time im trying to recreate the shares that were on that drive on another drive it will not allow me to create a share with the same name is there a way to remove them through ssh so i can recreate the shares with the right names ?
Message 1 of 6
mdgm-ntgr
NETGEAR Employee Retired
Re: Recreating Shares
So you had separate volumes for each hard drive?
What services did you have enabled on these shares?
Message 2 of 6
psxman_uk1
yes all JBOD i had ftp and smb only on the shares
Message 3 of 6
mdgm-ntgr
So you may need to edit the samba and proftpd config (under /etc/frontview if I recall correctly) as well as edit the readynasd sqlite3 database.
Message 4 of 6
xeltros
Apprentice
I confirm that there is a /etc/frontview/proftpd folder for FTP config.
/etc/frontview/proftpd/Shares.conf and /etc/frontview/samba/Shares.conf are probably the files you seek.
I believe the sqlite database should be located in /var/readynasd/db.sq3
That said, I would create a support ticket and get the support to do it if this is possible, or just wait for the replacement as the manipulation on the sqlite database may void the support until a factory reset.
You may also be able to use the mount command to recreate the arborescence and point to another resource without editing the conf. Not sure it is possible though.
Message 5 of 6
psxman_uk1
Replacement drive arrived tried to re create volume and shares no joy logged a call with l3 wating on a fix from them
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1719 views
  • 0 kudos
  • 3 in conversation
Announcements
