- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Refer to 2017 post " Cannot delete share due to Snapshot deletion error "
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problem. I can't delete a share because of unseen snapshot(s). There is a solution posted with this 2017 post but I don't understand the solution presented. Can someone dumb it down for me and help me delete a useless share folder?
thank you..............don
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@donlingg wrote:
I don't know what "ssh" is or "btrfs".
That suggests that a better path for you is to use paid support (my.netgear.com). Per-incident support would be about $75 (though that might vary for other geographies). You could also do a factory reset, reconfigure the NAS, and restore all the files from a backup. Painful, but that won't cost you anything but your time.
SSH: Secure Socket Shell. This is a way to log into the NAS that gives you the ability to enter linux commands. If you have no experience with linux commands, there is a pretty high risk you would do damage. If you've ever run Windows commands from the command prompt, that will give you some idea of what's involved.
BTRFS: B-Tree File System. This is the file system used for the NAS data volume. ReadyNAS snapshots are a feature of this particular file system. https://en.wikipedia.org/wiki/Btrfs
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Refer to 2017 post " Cannot delete share due to Snapshot deletion error "
It's hard to know what to "dumb down", since you didn't link to the old post.
Can you look at this one, and tell us what you need simplified? https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/hidden-snapshots-wont-delete/m-p/17...
Note that post does assume that ssh is enabled on your NAS, and that you do know how to log in with ssh.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your response. I don't know what "ssh" is or "btrfs". How do access it on the NAS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
