- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Remote FTP access to my readynas duo
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I recently decided to use a nas that I had at home because Google Photos no longer has unlimited space in the cloud.
The ReadyNas duo works perfectly on my local network. So I decided to try accessing from another network.
The problem is that I cannot connect from another network with the FTP protocol.
I have already tried following this tutorial: https://fredriklofter.com/setup-ftps-on-your-readynas-duo/
but I still cannot access from another network. Does somebody knows why it could be?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Remote FTP access to my readynas duo
There are many things that can go wrong in that procedure. If you've tested that everything works on your local network, then the most likely cause is that the device (a phone?) isn't finding the NAS. Do you have a static public IP, are you using a DDNS service to direct access to your IP, or are you doing something else?
If you've not tested that it works locally, then do that and come back with any errors you get.
Your NAS is very old with outdated security, so you are potentially opening yourself up to problems. If your router supports it, setting up remote access via OpenVPN may be a better way to go. There is an OpenVPN client for both IOS and Android.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think the problem is that the nas is connected to a secondary router that creates a new network.
It goes something like this:
Nas-------Router2(with another network)----router1
How should I configure the first router, so that it redirects to the nas or to the second router and the second router to the nas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Forward the ports you are using for FTPS from router1 to router2. Then forward them again to the NAS.
Also, use IP address reservation to make sure that router2's WAN port always gets the same IP address from router1, and also use IP address reservation to make sure the NAS always gets the same IP address from router2.
You'll also want a DDNS service to reach the NAS, since router2's WAN IP address will change from time to time. That can be deployed on either router1 or router2.
Be careful to always use ftps, and to use a strong password on the ftp user account. Normal FTP is unencrypted, so the credentials can leak if you accidentely use ftp.
A more secure approach is to deploy OpenVPN on router2 - though that might require a router upgrade. Netgear Orbi and Nighthawk routers all have OpenVPN (and DDNS) built in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried that but i can't get it to work.
Movistar router is the first router and afoundry is the second router.
There's a link to some screenshots: https://mega.nz/file/W0xzQAxJ#LAW5P8uGvT_BI0dsPjAZ6DEVa7ItWkl6_TXxfMYNE4g
https://mega.nz/file/m54nRA6J#0hZlwe1nJMKkl6kBBQUHSCJAJBkPSIMH9uZQiQog-SQ
https://mega.nz/file/uohxlIra#HBKC6yuKrbby5Q5b2vftR_YiBOPIChsL8mSxICWET4U
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the second network provided by the second router really necessary? If it's mainly there to provide a switch and secondary WiFi access point, it may be able to be configured as an access point instead of a router. Whether it can and how to do that is model dependent.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately it is necessary
- Mark as New
- Bookmark
- Subscribe
- Permalink
On both routers, ftp control (22/tcp) and the ftp-data range configured on the server must be port forwarded. Also, both routers must be checked for possible local ftp services which must be disabled therefore.
Doing so would allow using plain ftp (typically also possible by the ftp-algs in place on many routers) and ftps (resp. ftpes to be correct).
Be aware the referred article does also include the sftp config - while it's very complete, it does cover different protocols (sftp is NOT ftp, it's ssh)
For troubleshooting, you need a comprehensive ftp application like FileZilla where you can enable verbose resp. detailed log while using the mobile connection. Typical mobile phone ftp clients re by far not helpful enough.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@schumaku is correct on the configuration (though you can change the main port to something other than 22 if you wish).
I'm not seeing the port forwarding in this particular screenshot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@STG2005 wrote:
I think I found the Movistar router port forwarding
that's adding a firewall rule, not port forwarding. assuming your movistar router is a Mitrastar model -> Manual-de-fabricante-Router-Fibra-Optica-Mitrastar-HGW-2501GN-R2.pdf p.86 ff.
