× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Remove but not Replace
MattNeimeyer
Guide
I currently have 4x3TB + 2x2TB drives in my Ultra 6 running 6.8.0 in a single X-Raid array.
I'd like to remove the 2x2TB drives, leaving the 4x3TB, and I have ample free space to support that but when I search on remove drive I can only find how to remove and then replace. Is this possible?
Thanks!
P.S. I labeled this "Adding Disk" because I assume the one would lead to the other?
Model: ReadyNAS RNDU6320|ReadyNAS Ultra 6
Message 1 of 2
Accepted Solutions
Guru
Re: Remove but not Replace
You can't shrink an XRAID array.  To do what you want, you'll need to destroy the volume, which will delete all your data.  The simplest method is to remove the two disks and do a factory reset.
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 427 views
  • 0 kudos
  • 2 in conversation
Announcements
