× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Removed Drive (Degraded Volume). Will It Balance?
I purposefully removed one of the drives from my RN316 because I am transitioning to a newer server and need the drives. My RN316 now has a "degraded volume." My question is, will the RN316 eventually spread out the data evenly among the remaining 5 drives (given that there is plenty of space on the entire volume) to eventually become a redundant array again? Or, is there a way I can force this?
Model: RN31600|ReadyNAS 300 Series 6- Bay (Diskless)
Message 1 of 7
Accepted Solutions
Sandshark
Sensei
Re: Removed Drive (Degraded Volume). Will It Balance?
@StephenB wrote:
No.
 Well, actually yes.  It will spread the data out among the drives of the  non-redundant array.  It will not re-structure the RAID to use only the remaining drives and regain redundancy (and lose capacity), which is what @StephenB thinks you really mean (and you probably do).
Message 3 of 7
All Replies
Guru
No.
It can be done with SSH, and there are some posts here that outline the process.
It's not something you should attempt w/o a full backup of the files.
Message 2 of 7
Sandshark
Sensei
No.
Message 3 of 7
Okay, so in any case, the only way to regain redundancy is to insert another drive, correct? Does it have to be a drive of the same size as was removed (6 TB)? Or can I insert a smaller drive (1.5 TB) and still get redundancy? Note: I have only used 10 TB of the 36 TB originally in the server.
Message 4 of 7
Guru
 It has to be the same size or larger.
RAID creates a virtual disk that the file system users.  The RAID itself works the same way no matter how much free space there is file system.
FWIW, your data and parity blocks are already evenly spread across the drives (as are the RAID parity blocks).  The missing data (from the drive you removed) is being reconstructed on-the-fly from the remaining blocks.  That will reduce your performance.
Message 5 of 7
Sandshark
Sensei
Which is why initially filling the NAS is not a wise move unless you really need all the space right away.  Too late on this one, but not on the replacement.  As @StephenB said, the data is spread over all the drives, there aren't unused, idle ones.  So, they all get hours of use on them and can fail at similar times.  Adding drives as they are needed means the added ones are newer (and likely less expensive by the time you need them).  It's one of the big advantages of XRAID over other RAID implementations.
Message 6 of 7
Got it. I will only use two drives in the new NAS and reserve the other four for later expansion. Thank you.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1831 views
  • 0 kudos
  • 3 in conversation
Announcements
