× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Repeated'disk dead' failures that weren't, ReadyNAS Ultra 4+
mklement
I've had 4 instances of my Readys Ultra 4+ reporting a disk as dead - months apart.
Every time it turned out that the disk was NOT dead, and reinserting it carefully made it magically spring back to life and resync.
Nothing in the logs (as viewed through FrontView) suggests any problem with the drives. After reviving, no SMART problems are reported.
At least two different disks were involved in the 4 incidents.
I'm running the latest firmware, but the incidents span at least two different firmware versions.
Any help is appreciated.
Michael
Message 1 of 5
mdgm-ntgr
NETGEAR Employee Retired
Re: Repeated'disk dead' failures that weren't, ReadyNAS Ultr
What model drives? What's the drive firmware version. (can check under Status > Health > SMART+) in Frontview.
Message 2 of 5
mklement
Thanks for following up.
At least 2 of the disks involved in the incidents are Seagate drives:
Model: ST2000DL003-9VT166
Serial: <REMOVED BY MODERATOR>
Firmware: CC3C
It is possible that ALL my incidents involved just those 2 drives, but I'm not sure.
Message 3 of 5
mdgm-ntgr
That disk needs a firmware update. See http://www.readynas.com/forum/viewtopic.php?f=24&t=64510
Message 4 of 5
mklement
Thank you, I really appreciate your help - would not have occurred to me that a disk's firmware could be the problem.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1034 views
  • 0 kudos
  • 2 in conversation
Announcements
