× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Rsync Fails 2120 @ 6.9.2 to 3138 @ 6.9.2
Mrdavepa
I am trying to backup two readynas's connected by a presistent VPN.
I want to backup a share on the 2120(192.168.44.12) to the 3138 (192.168.44.139) and visa versa.
I have tried using windows and Rsync, the backups will not run.
Both systems have Rsync enabled. When I set the job up on the 2120, I can see the rsync directory on the 3138. Both systems have the other system's IP enabled.
I can choose test connection with and without login credentials. The test completes.
When I run the backup, I get a log error:
Backup Source: [Serverbackups]/
Backup Destination: [remote:rsync]/192.168.42.139::OrtmanVM
Backup Start Time: Fri Jul 20 2018 11:45:27
Backup Finish Time: Fri Jul 20 2018 11:45:35
Backup Status: Fail: Error in data stream. Check remote Rsync server settings.
Failed to run rsync, return rc 12
'rsync' command returns rc=12
sending incremental file list
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: error in rsync protocol data stream (code 12) at io.c(235) [sender=3.1.2]
 It doesn'tatter what I try it fails.
Model: RN21241D|ReadyNAS 2120 1U 4-Bay
Message 1 of 3
Guru
Re: Rsync Fails 2120 @ 6.9.2 to 3138 @ 6.9.2
Did you confirm that the destination path is correct?
Message 2 of 3
Mrdavepa
I think I got at least the backup at least running. There are was a setting off on the share under Rsync. Don't know if that will fix it but its running at the moment.
Model: EDA500|ReadyNAS Expansion Chassis 5-Bay
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 682 views
  • 0 kudos
  • 2 in conversation
Announcements
