- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rsync errors
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rsync errors
I am getting errors with my Rsync errors. Nothing has changed in my setup or settings. Any Ideas?
This is a backup job between two identical NAS box's RN314 with latest firmware 6.9.0
Both have over 1TB of free space.
Connection tests successfully.
Backup Job Name: Work
Backup Job Type: Incremental
Protocol: rsync
Backup Source: [remote:rsync]/***.***.***.***::Work
Backup Destination: [Work]/
Backup Start Time: Fri Nov 24 2017 17:05:04
Backup Finish Time: Sat Nov 25 2017 0:31:14
Backup Status: Fail: Connection cannot be established. Check the connection and authentication, if required.
Failed to run rsync, return rc 5
'rsync' command returns rc=5
rsync: did not see server greeting
rsync error: error starting client-server protocol (code 5) at main.c(1666) [Receiver=3.1.2]
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rsync errors
My own rsync backups worked with no issue on 6.9.0.
Though you likely already did this, you might confirm that destination NAS IP address didn't change. If the NAS use NIC bonding, perhaps try temporarily breaking the bond.
You could also try rebooting the destination, and see if that makes any difference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rsync errors
Both NAS boxes had bonded NIC connections. I have removed the Bonded settings and will try again.
Thanks. Is this a issue with the latest firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rsync errors
There were issues with bonding - and Netgear pushed out some hot fixes. I think there are more network fixes in 6.9.1, so you might want to upgrade to that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rsync errors
I don't see the 6.9.1 is avalible yet. Is it still in Beta?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rsync errors
No, it is released - but I don't think it's being pushed through the update servers quite yet. You can get a manual install here: https://kb.netgear.com/000051531/ReadyNAS-OS-6-Software-Version-6-9-1
