- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rsynch backup from RN214 to RN104. Cannot connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am running RN214 and RN104 both with the current FW (6.9.1).
Upon setting up the Rsynch backup between the two, the backup job cannot connect to the backup (RN104) system. Although when I use the test button it goes through ok. The other error I see is Failure during copy.
Any thoughts as to what I can check?
I've tried various ports.
I've made sure shares on both systems are Rsync read/write.
Not sure where to go next!
Thanks for your help in advance
John
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is an example of the log for a failed attempt:
Backup Job Name: Test
Backup Job Type: Full
Protocol: rsync
Backup Source: [Test]/
Backup Destination: [remote:rsync]/192.168.1.68::Test
Backup Start Time: Mon Jan 15 2018 17:19:09
Backup Finish Time: Mon Jan 15 2018 17:19:09
Backup Status: Fail: Failure during copy.
Failed to run rsync, return rc 10
'rsync' command returns rc=10
rsync: failed to connect to 192.168.1.68 (192.168.1.68): Connection refused (111)
rsync error: error in socket IO (code 10) at clientserver.c(125) [sender=3.1.2]
Changed port to 873 and that fixed it.
Thanks!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rsynch backup from RN214 to RN104. Cannot connect
Use 873 for the port. Also, if you are using the hostname of the remote system, then try using it's IP address.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Protocol: rsync
Thanks!
