× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Setting permissions
John_Exhart
Guide
Setting permissions
Hello
We have a RN314 storage unit and in our initial setup created individual accounts all part of the USERS group with Read/Write capability. We've now attempted to move certain individuals in specific Groups such as Sales, Marketing, etc. The individuals have now lost the ability to save files in folders created by other users. Can anyone help with resolving this problem?
Thanks,
John
Model: RN31400|ReadyNAS 300 Series 4- Bay (Diskless)
Message 1 of 2
Sandshark
Sensei
Re: Setting permissions
Um, that's kinda the point of having separate groups -- to keep folks that shouldn't be doing so from changing another's files.  For each folder, there is a setting for "Default access", and it sounds like you want to check the box that says Specify permission when new file/folder is created, otherwise inherit permission from parent.  But you are probably going to have to clean up some existing permissions as well.  You can do that from the NAS GUI, but it is often easier to use Windows to do so (assuming you have only Windows users).  Right-click on the folder in Windows, then select Properties, then Security, then Advanced.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 504 views
  • 0 kudos
  • 2 in conversation
Announcements
