- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Share Disappeared
- Mark as New
- Bookmark
- Subscribe
- Permalink
Share Disappeared
I've recently noticed that one of my shares has disappeared from Frontview. However, when I view my ReadyNAS from my PC filesystem, while it isn't listed as one of the shares, there is another share called "data"; when I open that folder, I see my missing share - including all of its contents. Any ideas how to restore this folder to its full share status, and have it show up in Frontview?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Share Disappeared
This is the full NAS data volume. The good news is that your data is still there. Though somewhat off-topic, RAID isn't enough to keep your data safe - if you don't have a backup plan for your NAS, I suggest that you consider putting one in place. It would be prudent to do that now (before you write more data to the NAS or move files around).
Well, it would be good to sort out what happened. Perhaps @JohnCM_S can see if Netgear engineering wants to take a look.
But one way to fix this is to rename the folder, then create a new share from the Web UI. Then move the files from the renamed folder into the share.
You'll find that you won't be able to delete the old share from the PC (and the snapshots will still be there also, though you won't see them). Both the old share and it's snapshots can be removed using ssh if you know how.
Another way to resolve this is to back up the NAS, do a factory reset, rebuild it, and restore all the data from the backup. Though it's a lot more work, it gives you a completely clean system - which you don't have now. And as noted above, if the NAS is used for primary storage it does need to be backed up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the advice. I'll try renaming the folder and creating a new share. I'll let you know how it goes. And yes, I have a backup plan - I replicate to another ReadyNAS314 at my mother-in-law's house.
