- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Shares goes read-only after a while after upgrade to 6.8.0
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
After upgrading to 6.8.0 I have a strange behavior.
After every boot, everything is fine for some time (up to half an hour) and then file system goes read only.
After boot:
root@NasSebUltra6:/# mount | grep -v snapshot | grep '(ro' tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
After some time:
root@NasSebUltra6:/# mount | grep -v snapshot | grep '(ro' tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755) /dev/md127 on /data type btrfs (ro,noatime,nodiratime,nospace_cache,subvolid=5,subvol=/) /dev/md127 on /home type btrfs (ro,noatime,nodiratime,nospace_cache,subvolid=256,subvol=/home) /dev/md127 on /apps type btrfs (ro,noatime,nodiratime,nospace_cache,subvolid=257,subvol=/.apps) /dev/md127 on /run/nfs4/home type btrfs (ro,noatime,nodiratime,nospace_cache,subvolid=256,subvol=/home)
Strange thing is, there no new entry in system logs. It juste goes in readonly until next reboot.
I launched a scrub just in case, but I don't really believe it will chance anything.
Does anyone have some idea about how to solve this ?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
This morning I gave up: didn't see any possible solution as the more I looked the it seemed the raid itself became corrupt (not read/write error in the smart data of the disks)
=> I just did a factory default and am downloading my last backup
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Shares goes read-only after a while after upgrade to 6.8.0
As I feared, scrub didn't solve the problem and desmg raise lots of errors
[ 52.671108] BTRFS critical (device md127): corrupt leaf, slot offset bad: blo ck=863109120, root=1, slot=159 [ 55.351256] BTRFS error (device md127): bad tree block start 566935740547 384 36864 [ 55.370366] BTRFS error (device md127): bad tree block start 566935740547 384 36864 [ 55.917422] BTRFS error (device md127): bad tree block start 566935740547 384 36864 [ 55.990251] BTRFS error (device md127): bad tree block start 566935740547 384 36864 [ 63.156939] BTRFS error (device md127): bad tree block start 566935740547 384 36864 [ 63.170322] BTRFS error (device md127): bad tree block start 566935740547 384 36864 [ 63.195064] BTRFS error (device md127): bad tree block start 566935740547 384 36864 [ 63.195291] BTRFS error (device md127): bad tree block start 566935740547 384 36864 [ 63.490218] BTRFS error (device md127): bad tree block start 566935740547 384 36864 [ 63.490426] BTRFS error (device md127): bad tree block start 566935740547 384 36864 [ 64.986349] BTRFS error (device md127): bad tree block start 566935740547 384 36864 [ 64.986675] BTRFS error (device md127): bad tree block start 566935740547 384 36864 [ 64.987037] BTRFS error (device md127): bad tree block start 566935740547 384 36864 [ 64.987405] BTRFS error (device md127): bad tree block start 566935740547 384 36864 [ 65.370875] BTRFS critical (device md127): corrupt leaf, slot offset bad: blo ck=863109120, root=1, slot=159 [ 65.370895] BTRFS: error (device md127) in __btrfs_free_extent:6968: errno=-5 IO failure [ 65.370897] BTRFS info (device md127): forced readonly [ 65.370901] BTRFS: error (device md127) in btrfs_run_delayed_refs:2956: errno =-5 IO failure [ 65.371117] BTRFS error (device md127): pending csums is 360448
But all was ok until upgrade 😞
Is there any mean to repair this ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Keligh,
It does appear that after firmware upgrade the NAS will for some reason will automatically go to read only mode. I have not seen similar concern/issue raised on support. When the NAS goes to read only mode do you need to reboot the NAS to work again and in turn goes to a cycle is this correct? May we ask for the complete logs of the NAS, you may use file sharing website like wikisend and just PM the download link.
Marty_M
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
