Orbi WiFi 7 RBE973
Reply
Smart Tv has stopped playing movies from my ReadyNas
VicMovieBuff
HI,
Last Night i wanted to watch a movie from my readyNas on my Samsung Smart Tv and it told me there were no movie files on the server, yet in my TV shows folder it showed all of those no problems., Now it keeps saying it cant connect and goes back to main menu.
I have been watching without any issues for the last 12 months, and now suddenly it decides it doesn't want to play anymore.
I have been looking at getting a better Model, but since i can still watch using the Plex App on my Xbox one, i am wondering if it may be a TV issue rather than the NAS unit?
Any help offered would be greatly appreciated.
Thanks
Model: RN10200|ReadyNAS 100 Series 2- Bay (Diskless)
Message 1 of 35
Guru
Re: Smart Tv has stopped playing movies from my ReadyNas
Did you try rebooting the ReadyNAS?
Message 2 of 35
VicMovieBuff
Yep sure did, reset the router as well. nothing has worked
Message 3 of 35
Guru
Maybe try enabling ReadyDLNA on the share, and see if the Smart TV sees that.
Does your Samsung have a plex app?   Or are you using the built-in DLNA client?
Message 4 of 35
VicMovieBuff
The Tv SEE's the Readyshare as it is showiing as a Readyshare Icon in the Input menu, but when i try to connect to it i get a message saying the action cannot be performed at this time. that was after i restarted the NAS unit. Before that it logged into the unit, saw the MOVIES folder and TV Shows folder, i could watch the TV shows, but when i went into movies folder to select one to watch it said there were no video files in the folder. yet Plex can see it and watch it ( using my Xbox One) i dont like the plex app on the tv as it is very slow compared to the xbox app.
I have tried updating them both on NAS and TV but still very slow
Message 5 of 35
Guru
ReadySHARE icon?  I was thinking the ReadyDLNA server on the NAS (which would need to be enabled for each share).
Did you also double-check the plex server settings, and see that the plex dlna server is enabled?
Message 6 of 35
VicMovieBuff
yes Readyshare icon, on my smart Tv when i select the input button on the remote, i have a icon that shows up that says ReadyShare NAS. thats how i have always accessed the movies etc.  and it has always worked great. until last night
Message 7 of 35
VicMovieBuff
and yes the server has that option enabled
Message 8 of 35
Guru
Does anything change if you disable the option, but keep ReadyDLNA enabled?
Message 9 of 35
VicMovieBuff
Message 10 of 35
VicMovieBuff
i hope those two images help with my explanation? dont know how else to put it lol
Message 11 of 35
Guru
Both Plex and Allshare are showing up in the TV (both DLNA, and I am thinking both are originating from the NAS).
If you turn DLNA off in plex, you should still see AllShare.  I'm wondering if that changes the behavior.
Message 12 of 35
VicMovieBuff
They have always shown up with no issues to playback. but i can give it a go to see if it makes a difference
Message 13 of 35
VicMovieBuff
just disabled DLNA on the plex and it made no difference
Message 14 of 35
Guru
You might want to try a manual rescan of the ReadyDLNA database next.  Another thing you can try is to reset the share permissions for the share holding the movies.
Message 15 of 35
VicMovieBuff
ok will do that and let you know how it pans out. database rescan will take quite a while 🙂
Message 16 of 35
VicMovieBuff
Share reset made no difference. Library update is in progress
Message 17 of 35
brentm
Hi.  Was this resolved?  I am having same problem on my Samsung TV (and a similar problem with music on my Cambridge Audio music streamer).  All was working until around November.
Message 18 of 35
FramerV
NETGEAR Employee Retired
Hi brentm,
Welcome to the community.
May I ask what model as well as firmware version of ReadyNAS are you using?
Message 19 of 35
brentm
Hi FramerV.
The model is RN10200.  Firmware version is 6.6.0
Message 20 of 35
Guru
Are you using plex or ReadyDLNA?
Message 21 of 35
brentm
ReadyDLNA
Message 22 of 35
Guru
Perhaps double-check that DLNA is enabled in the media shares, and then do a manual scan from system->settings.
Message 23 of 35
brentm
Hi StephenB
Thanks.  I've just checked and DLNA was selected.  I've also rescanned.  Still not working . I noticed however that I could see my pictures but still no video or music.
Message 24 of 35
Guru
Did anything change on the NAS or your home network generally around the time it stopped working?
One other possibility is that some media file has an issue that is causing the media scanner to crash. That would explain why you see photos but nothing else.  You could try turning DLNA off on all shares, and then creating a test share, copying a few music and video files that you know worked before. Then enable DLNA on just that test share, and scan again.  Let us know if files will stream from the test share.
Message 25 of 35
Top Contributors
Discussion stats
  • 34 replies
  • 5717 views
  • 0 kudos
  • 8 in conversation
Announcements
