× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
* Solved * Case#:15848658 > ReadyNAS RNDX400E won't expand.
vuilverwerking1
Hi,
ReadyNASRNDX400E
RAIDiator 4.2.17
3 X 1.5 TB SAMSUNG HD154UI [1397 GB]
Added a fourth drive SAMSUNG HD154UI [1397 GB]
ReadyNAS detected, checked, resynced.
ReadyNAS doesn't expand?
All 4 drives are OK.
After the complete proces the total RAID volume stays at 2769 GB.
I expected 4191 GB.
Turned on Volume scan and Quota control at Shutdown.
Unplugged power from the ReadyNAS for 10 minutes.
Plugged in power, ReadyNAS booted. FS Scan OK. Quota control OK.
But no expansion.
Yes, i know the drive's are not (yet) on the HCL.
Message 1 of 22
mdgm-ntgr
NETGEAR Employee Retired
Re: Case #: 15848658 > ReadyNASRNDX400E won't expand.
Please take a look at What To Do When Expansion Doesn't Start and see if the suggestions there help.
Ensure disk spin-down is disabled under System > Power. If you still have the "Disable Journaling" (not to be confused with "Disable Full Data Journaling" option which can safely remain checked) option under System > Performance ensure this is unchecked.
Please also download your logs (Status > Logs > Download all logs), extract the zip contents and post the contents of partition.log (please use the code tags, not the quote tags to enclose this).
Reboot the NAS. Wait 5-10 minutes and if expansion hasn't started do another reboot.
As you aren't using drives on the compatibility list I doubt NetGear would help with your problem.
Message 2 of 22
vuilverwerking1
OK;
- http://home.bott.ca/webserver/?p=550 URL doesn't work for me. I also tried that at another forum post. (website down?).
- Rebooting...... 😐
***** partition output for sda *****
Disk /dev/sda: 2930277168 sectors, 1.4 TiB
Logical sector size: 512 bytes
Disk identifier (GUID): 18D5BCF0-DEC4-4C30-987C-5A0124E0E7AC
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 2930277134
Partitions will be aligned on 8-sector boundaries
Total free space is 5108 sectors (2.5 MiB)
Number Start (sector) End (sector) Size Code Name
1 64 8388671 4.0 GiB FD00 Linux RAID
2 8388672 9437247 512.0 MiB FD00 Linux RAID
5 9437256 2930272064 1.4 TiB FD00 Linux RAID
Disk /dev/sda: 182401 cylinders, 255 heads, 63 sectors/track
Units = cylinders of 8257536 bytes, blocks of 1024 bytes, counting from 0
Device Boot Start End #cyls #blocks Id System
/dev/sda1 0+ 181688- 181689- 1465138583+ ee EFI GPT
/dev/sda2 0 - 0 0 0 Empty
/dev/sda3 0 - 0 0 0 Empty
/dev/sda4 0 - 0 0 0 Empty
Message 3 of 22
mdgm-ntgr
Partitioning looks fine. If all disks are like that then you have 4k sector alignment.
Message 4 of 22
vuilverwerking1
It all looks fine.
All the stages did go well.
But i don't get more space :cry:
Happy with my USB backup drive!!!
Message 5 of 22
mdgm-ntgr
Can you post a screenshot of Volumes > Volume Settings?
Message 6 of 22
vuilverwerking1
Yes Sir!
Message 7 of 22
vuilverwerking1
1st reboot no expansion.
2nd reboot, still no expansion.
Where can i find the [Force Expansion] button? :lol:
Message 8 of 22
vuilverwerking1
Re: Case #: 15848658 > ReadyNAS RNDX400E won't expand.
Hi MDGM,
Can you please tell me where i can find "Disable Journaling"?
It's not under System > Performance.
Vuilverwerking
Message 9 of 22
mdgm-ntgr
It's an obsolete option so it's no longer available.
Message 10 of 22
Jedi_Knight
Tutor
I would suggent continue working tech support as I seen you have support case open.
Message 11 of 22
vuilverwerking1
I recieved a mail that they will contact me.
Thanx for your feedback for so far...
Message 12 of 22
vuilverwerking1
Had contact with Tech Support.
It's a good thing you updated to verson 4.2.17 what I advise you to do is to make a Firmware re-installation anyway. How to do this you can find here:
http://www.readynas.com/kb/faq/boot/how ... e_firmware
Can you confirm that your using Flexraid?/expanable raid? Because if you use 3x 1.5TB this means that you should have 4.5TB (fysically about 3.8TB) It seems that you only user 2x 1.5TB harddisk that would make 3 TB, and fycically about 2.7TB.
If you mirror disks you can't add more disks than 2. (depending on the raid)
Please bare in mind that your harddisks are NOT on the compatibility list. This means that the nas can react different than it should.
Most important for me to know now: What RAID are you using? please inform me.
Firmware re-installation from flash was an option but did nothing for the expansion. 😞
RAID configuration isn't for everybody a well know part.
For so far i know, Flexraid isn't expandable....?
3 X 1.5TB in RAID = 3TB
Waiting for Tech Support again.
Message 13 of 22
mdgm-ntgr
Flex-RAID is expandable on 4.2.16+ but with more caveats than X-RAID2. X-RAID2 (which you are using) is a much simpler setup. Continue working with tech support.
Message 14 of 22
vuilverwerking1
Thanx,
Again learned something!
Message 15 of 22
vuilverwerking1
[2011/06/13 05:01:27 17849] do_lvextend: new value wrong: %, try:0
[2011/06/13 05:01:29 17849] Facts:vg_total=66852,vg_alloc=44488,vg_free=22364,lv_new=0,lv_total=%
[2011/06/13 05:01:29 17849] LINE 4309: exec command: lvextend /dev/c/c -l +0
New size (44488 extents) matches existing size (44488 extents)
lvextend: Add space to a logical volume
lvextend
[-A|--autobackup y|n]
[--alloc AllocationPolicy]
[-d|--debug]
[-h|--help]
[-i|--stripes Stripes [-I|--stripesize StripeSize]]
{-l|--extents [+]LogicalExtentsNumber |
-L|--size [+]LogicalVolumeSize[kKmMgGtT]}
[-m|--mirrors Mirrors]
[-n|--nofsck]
[-r|--resizefs]
[-t|--test]
[--type VolumeType]
[-v|--verbose]
[--version]
LogicalVolume[Path] [ PhysicalVolumePath... ]
[2011/06/13 05:01:29 17849] Expand second phase cmd=lvextend /dev/c/c -l +0, error:0x300, continue...
[2011/06/13 05:01:29 17849] LINE 4490: exec command: /frontview/bin/volumescan &
[2011/06/13 05:01:29 17849] LINE 446: exec command: echo "DOING_F_RESIZE" > /.os_V_E_continue
[2011/06/13 05:01:29 17849] LINE 4239: exec command: resize2fs -pf /dev/c/c
resize2fs 1.41.14 (22-Dec-2010)
The filesystem is already 728891392 blocks long. Nothing to do!
L3 Support solved the problem:
local_commands.log
df
pvscan
lvscan
cat /proc/mdstat
mdconfig
pvscan
pvdisplay
vgscan
vgdisplay .
vgdisplay
lvscan
cd /var/log/frontview/
ls -l
vi expand_md.log
cat /proc/partitions
sfdisk
sfdisk -d
sgdisk -p /dev/sdd
pvscan
cd /etc/lvm/archive/
ls
cat c_00020.vg
lvdisplay
lvdisplay -v
df
pvscan
vgdisplay -v
ls -l
cat c_00019.vg
pvscan
lvscan
ls -l
cat c_00018.vg
pvsdi
pvdisplay
lvscan
lvextend -l +22284 /dev/c/c
lvdisplay
pvdisplay
ls -l
cat c_00018.vg
ls -l
cat c_00016.vg
df
df
df -h
ps -ef
df
ps -ef
lvscan
pvscan
pvdisplay
df
ls
vi expand_md.log
ls -l
cat status.log-old
smartctl -a /dev/hdc
smartctl -a /dev/sda
smartctl -a /dev/sdb
smartctl -a /dev/sdc
smartctl -a /dev/sdd
ls -l
lvscan
cd ..
cd -
vi expand_md.log
df
lvscan
pvscan
df
lvscan
cd
Message 16 of 22
PapaBear1
Guide
Re: * Solved * Case#:15848658 > ReadyNAS RNDX400E won't expa
Interesting. I had forgotten about this thread yesterday when my NVX Pioneer would not exapand after replacing two of four ST31000528AS 1TB Seagate drives with 2 Hitachi HDS5C3030ALA630 3TB drives. I did a similar process last week with my NVX Business Edition, and after it had done the initial resync of the second drive, I got the message additional space was found for expansion and the expansion would take place after the next reboot. On the BE, that took place after the first reboot.
However, after at least four reboots on the Pioneer, no expansion was forthcoming. The only difference in the set up of the two machines is that I had installed the Bonnie++ add on to measure the file transfer speed. I deleted the add on, rebooted and got the message again that additional space was found. One final reboot and it started. Others may want to check their system for any add ons if expansion does not start.
Message 17 of 22
vuilverwerking1
I think the problem has to do with a 'Ghost' :shock: Snapshot option for NVX Pioneer Edition.
NVX Pioneer Edition does not support snapshot but it looks like it is the bottleneck for the expansion:
expansion.log:
[2011/06/12 00:23:18 27018] Facts:vg_total=66852,vg_alloc=44568,vg_free=22284,lv_new=22284,lv_total=%
[2011/06/12 00:23:18 27018] LINE 4309: exec command: lvextend /dev/c/c -l +22284
Snapshot origin volumes can be resized only while inactive: try lvchange -an
[2011/06/12 00:23:18 27018] Expand second phase cmd=lvextend /dev/c/c -l +22284, error:0x500, continue...
[2011/06/12 00:23:18 27018] LINE 4490: exec command: /frontview/bin/volumescan &
[2011/06/12 00:23:18 27018] LINE 446: exec command: echo "DOING_F_RESIZE" > /.os_V_E_continue
[2011/06/12 00:23:19 27018] LINE 4239: exec command: resize2fs -pf /dev/c/c
My Add-Ons:
- ffmpeg. v1.3 - Released by Super-Poussin ©
- NZBGET. v2.2 - Released by Super-Poussin ©
- PHP+Mysql Support v1.4 - Released by Super-Poussin ©
- Subsonic. v2.0.00 - Released by Super-Poussin ©
- Transmission. v2.22.09 - Released by Super-Poussin ©
Message 18 of 22
vuilverwerking1
Answer from L3 Support:
It may be because of snapshot.
If there is hiden invalid snapshot, expansion will not go.
If you have used remote or online fsck, but been killed ab-normally, there are/may be invalid snapshot as leftover.
I remember there was a snapshot on file /etc/lvm/archeive/c_0000*.log .
Message 19 of 22
Jedi_Knight
Tutor
🙂 Thanks for the update.
Message 20 of 22
langus
Hi,
I know this is a old post, I hope someone can help...
I suspect I have the same problem, how do I go about checking for a ghost snapshot, and once checked, how do I remove it?
Many thanks,
Llew
Message 21 of 22
mdgm-ntgr
langus this is an old dead thread. Please open a new thread with a tech support (http://www.readynas.com/support) case number in the thread title (subject of first post in the thread)
Please describe the symptoms you are experiencing. This will help with determining whether it's the same problem.
Message 22 of 22
Top Contributors
Discussion stats
  • 21 replies
  • 1912 views
  • 0 kudos
  • 5 in conversation
Announcements
