- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Something seems broken with iSCSI since 6.7.0
- Mark as New
- Bookmark
- Subscribe
- Permalink
Upgraded from 6.6.1 stable to 6.7.0 stable yesterday. Since then I can no longer mount my TrueCrypt containers residing on Readynas iSCSI volumes. Or, they mount after several minutes, but I can no longer see any data. What has changed regarding iSCSI?
Thick provision, no sync writes, no snapshots, no CHAP or connection lists.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Something seems broken with iSCSI since 6.7.0
Can you send in your logs (see the Sending Logs link in my sig)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your data volume is 98% full. We don't recommend filling a volume that full especially when using iSCSI.
Do you have data in ordinary shares? If so, can you backup some of those files and free up some space and see if that helps?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The device has only ever been used as an iSCSI drive. As such, it is created with the maximum LUN size allowed by NTGR, which for my unit is 7.354 TB according to the GUI. Only one LUN. There is nothing else in /data (verified with WinSCP) but a couple of NTGR settings files in /data/.apps etc. Only two apps are installed, smbplus and phpr6.
The GUI says "217.29 GB free of 8.17 TB" which indeed is a discrepancy, but that discrepancy seems to be precisely because of the upgrade from 6.6.1 to 6.7.0. New version of BTRFS acting up?
- Mark as New
- Bookmark
- Subscribe
- Permalink
root@link:~# btrfs fi df /data
Data, single: total=7.97TiB, used=7.96TiB
System, DUP: total=32.00MiB, used=992.00KiB
Metadata, DUP: total=512.00MiB, used=262.50MiB
GlobalReserve, single: total=96.00MiB, used=0.00B
root@link:/data# du -sh *
7.4T 8TB
0 Documents
0 home
0 Music
0 Pictures
0 Videos
- Mark as New
- Bookmark
- Subscribe
- Permalink
As you can see from initrd.log the device was factory defaulted in 2015/02/15 with 6.2.2 and the iSCSI volume was created and has been in use since then.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do/did you have Bit-rot protection or snapshots enabled on the LUN?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No and no (snapshots are set to Smart/Never and that is not an UI I remember seeing, when created I think the smart/custom setting didn't exist, correct?).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still it looks like there's been some fragmentation over time. iSCSI doesn't work well when the volume gets this full.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Frankly speaking, if there has been fragmentation, Netgear has created it by using the data drive as a temporary drive for updates or such. The data drive basically contains ONE FILE (the iSCSI file).
So how do I fix this?
Have you tried replicating the problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is your initiator?
I see a steady stream of messages about the initiator sending FUA requests, but the iSCSI target is configured to claim no support for FUA. I assume your Sync Writes setting is set to Disabled? Can you try changing it to Allowed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Microsoft initiator (on Windows 7 64-bit).
Interestingly, with sync writes enabled, I can now mount the volume again. Thanks for that!
Doesn't solve the space free problem though and that clearly happened when upgrading the firmware. Is it risk free in this situation to try rebalancing (from the UI)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your status.log shows your volume being over 95% full as far back as April 2016. It's not an issue caused by the upgrade.
Balancing shouldn't be attempted on a volume that full. That's not the solution. For optimal performance you should consider expanding your data volume (after updating your regular backup, of course).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there anything in particular this iSCSI volume is doing? We tried to reproduce the issue, but only got a single FUA write request during mount time, and none after that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Whatever. As stated before, the volume has been created using Netgear recommendations, and never used for anything but this iSCSI volume.
No, its only purpose is to host a TrueCrypt volume. Sync Writes has been off for performance reasons for a long time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now the free space is down to 210.09 GB, and the only thing done is upgrading to 6.7.3 and my normal iSCSI traffic.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would run 6.7.4 rather than 6.7.3.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Updated to 6.7.4. Ran a balance for good measure. 210.02 GB free.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please send in fresh logs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problem.
My ReadyNas is solely used as iSCSI Target.
I have created a LUN with 3.269TB (90% of Space) and activated Bit-Rot Protection for this LUN.
root@NAS:~# btrfs fi du /data/RB00_READYNAS02/.iscsi/ Total Exclusive Set shared Filename 3.27TiB 3.19TiB - /data/RB00_READYNAS02/.iscsi//iscsi_lun_backing_store 0.00B 0.00B - /data/RB00_READYNAS02/.iscsi//.serial_number 3.27TiB 3.19TiB 75.14GiB /data/RB00_READYNAS02/.iscsi/
root@NAS:~# btrfs fi df /data Data, single: total=3.62TiB, used=3.62TiB System, DUP: total=8.00MiB, used=480.00KiB Metadata, DUP: total=5.00GiB, used=4.16GiB GlobalReserve, single: total=512.00MiB, used=0.00B
root@NAS:~# du -h --max-depth=2 /data | sort -hr 3.3T /data/RB00_READYNAS02/.iscsi 3.3T /data/RB00_READYNAS02 3.3T /data 1.7M /data/.apps 1.6M /data/.apps/.freeapps 76K /data/.apps/.readydlna 20K /data/._share 16K /data/._share/RB00_READYNAS02 0 /data/.vault 0 /data/.timemachine 0 /data/.purge 0 /data/home 0 /data/.apps/.xdg 0 /data/.apps/.forked-daapd 0 /data/.apps/DO_NOT_DELETE
Where have the missing 350GiB gone?
Best Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Got it!
The iSCSI File is heavily fragmented (over 1 Million Extents!)
I disabled CoW for the file (chattr +C <file>) and defragmented extents smaller than 100M (btrfs fi defrag -f -t 100M /data/RB00_READYNAS01/.iscsi/iscsi_lun_backing_store).
When enough space was freed up (>50GB) I stopped defragmentation and started again but this time for extents smaller than 10G.
I hope the file won't fragment again this heavy after i disabled CoW.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can't disable CoW on existing files that contain data. So the chattr command you ran had no effect.
You may be able to improve fragmentation characteristics by adding the "autodefrag" mount option to the /etc/fstab entry.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, well, well.
iscsi_lun_backing_store: 1616701 extents found
- Mark as New
- Bookmark
- Subscribe
- Permalink
Even though repeated defragging has freed up some space on the drive (835 GB "free" as of now), the originally reported problem still stands: when "sync writes" are disabled, TrueCrypt iSCSI volumes are no longer mountable since 6.7.0.
