Orbi WiFi 7 RBE973
Reply
Start all over
kiiilden
Start all over
hi there..
if i want to put in a new harddisk in my Readynas duo, which allready got movies on. Will they be deleted when i start the nas or will it just install the os and dont delete anything?
Message 1 of 14
mdgm-ntgr
NETGEAR Employee Retired
Re: Start all over
It will wipe the disk, so all data will be deleted. You must backup your data first if you want to keep it. If you value your data you should backup your data regularly anyway.
Glad you asked before inserting the disk.
Message 2 of 14
kiiilden
Re: Start all over
thx for the fast answer.. believe me, im glad ive asked too 🙂
What if i use another hdd first to get to os on, and then put in the other with the files on ? Would it still delete the files?
Message 3 of 14
mdgm-ntgr
Re: Start all over
It still needs to wipe the disk.
The OS is stored on both disks. The NAS needs to format all disks that are installed.
Message 4 of 14
kiiilden
Re: Start all over
ok, thx.
Message 5 of 14
Guru
Re: Start all over
So first install a different hard drive of the same size, create shares on its C volume, and copy your files onto it over the network. Then install the drive with the movies as the second drive. It will be wiped, and you will end up with a RAID-1 C volume (protected against 1 drive failure). This will be the same size as your existing drive (not 2x).
RAID is helpful, but doesn't guarantee data safety. So you will need a backup of some kind - a USB drive perhaps.
Message 6 of 14
kiiilden
Re: Start all over
is it not possible to install a 1 tb and a 2 tb hardrive ? or does it have to be same size ?
Message 7 of 14
Guru
Re: Start all over
If you using the default xraid2, you want the drives to be the same size.
If you start with a 1 TB drive, you can add a 2 TB. But you are wasting space (you end up with a 1 TB shared volume with redundancy)
If you start with a 2 TB drive, the system will not let you add a 1 TB.
You can use jbod (flexraid), which will let you create two volumes (one on each disk). Then you'd have 3 TBs total, but wouldn't have any RAID protection at all. Generally new users are better off with the default xraid-2.
Message 8 of 14
kiiilden
Start all over
Thanks.
I will put in the 2tb drive and get me one more 🙂
Message 9 of 14
kiiilden
Re: Start all over
i now installed a new formated 2 tb WD green harddrive.
in RAIDar, first i see, booting and then i says update - and then i just stand like this (see pic below) for several hours. at my fathers place, he´s gonna have it, it stod like that for 24 hours, and then i turned it off, because the fan was to loud. now i will try at home, and it´s no better. i´ve tried to reset it with the reset buttom at the back. turn off power, hold down reset, turn on power, wait for light in disc 1-2. still nothing ? im a doing something wrong ?
Message 10 of 14
Guru
Re: Start all over
Generally you don't want to format the disks before you insert them.
Also, were you installing a second drive, or was this the initial drive?
Message 11 of 14
kiiilden
Re: Start all over
i thought i should do it before insert it :s
this is the initial drive. i had a 320 gb in it before it put the 2tb in ..
Message 12 of 14
Guru
Re: Start all over
Is RAIDar detecting the NAS at all?
You can try removing the drive, connecting it to a Windows PC, and deleting all volumes on the drive with Windows Disk Manager (right-click computer, select "Manage"), and inserting it again. Deleting the volumes will return the disk to an unformatted state.
Message 13 of 14
kiiilden
Re: Start all over
I deleted the volumes and tried again, and now its up and running 🙂
Thx alot StephenB !
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 2152 views
  • 0 kudos
  • 3 in conversation
Announcements
