Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Sync failed - No Volume Exisits - HELP...
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-04-13
09:17 AM
2014-04-13
09:17 AM
I have a ReadyNAS Pro Business Edition [X-RAID2].
did have all 2tb drives. been replacing each drive with a 3tb wd red.
last two drive replacements took about 8 to 10 hours to resync
put in 5th 3tb a few days ago and all started well. However on checking the next morning it said it would be thousands of hours to re sysnc. at this point it was at 50.5%. checked this morning and it was at 51% (8 hours later). Could not log in from computer. decided to do a soft reboot from power switch. pressing button just shut the system down!! no gentle shutdown. I restarted the NAS and system now says No Volume Exists!!
Log says
Severity Date Message
Sun Apr 13 08:52:23 PDT 2014 System is up.
Sun Apr 13 08:52:23 PDT 2014 The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume. Software media AdamFran webroot Ebooks
Sun Apr 13 08:52:00 PDT 2014 Volume scan failed to run properly.
Sat Apr 12 06:25:02 PDT 2014 Volume C is approaching capacity: 81% used 1.8T available
Fri Apr 11 23:26:27 PDT 2014 RAID sync started on volume C.
Fri Apr 11 23:25:59 PDT 2014 Data volume will be rebuilt with disk 4.
Fri Apr 11 23:23:50 PDT 2014 New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 4]
Fri Apr 11 23:21:32 PDT 2014 A disk was removed from the ReadyNAS. For full protection of your data volume, please add a replacement disk as soon as possible.
Fri Apr 11 23:21:32 PDT 2014 Disk removal detected. [Disk 4]
Health shows disk4 blinking green and resync
If I go to Volume Settings it says "No volume exists. Some menu options are available only if a valid volume exists"
Have I lost all my data? Anything I can do to recover? should i try to pull disk 4?
Thanks
Adam
Log says
Thanks
Adam
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-04-13
02:44 PM
2014-04-13
02:44 PM
Re: Sync failed - No Volume Exisits - HELP...
Contact NetGear support.
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-04-19
04:39 PM
2014-04-19
04:39 PM
I contacted Support. They want $380 to help. I now just need to be 100% sure they will be able to help recover my data before spending the money.
Anyone any safe ideas for me to try?
Message 3 of 3
