× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Transmission Web Interface won't work on ReadyNAS Duo v2
Space_Munky
Hi. I have a ReadyNAS Duo v2 which was running a WD Red 2TB for many years with no issues. Since I first had it I had run Tranmission add-on with no issue. I recently purchased a new WD Red 4TB for my ReadyNAS. I preformed a factory reset and installed the new HDD. I've re-installed Transmission however now I am unable to open the Transmission Web Interface. I have tried both with Chrome and IE, but both give me the "This site can't be reached" window.
I have looked through quite a few posts, but I haven't found anything that would help me so far. I have some tech knowledge but I am not super proficient. Hoping someone can help me out with a relatively easy fix.
Model: ReadyNAS Duo V2
Firmware: RAIDiator 5.3.13
Memory: 256MB
RAID Type: X-RAID2
Host Name: READYNAS
DNS/Gateway: 10.0.0.1
IP: 10.0.0.21
Transmission v2.71.01
It says the Transmission web Interface is http://10.0.0.21:9091/
Below is my settings.json
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": false,
"blocklist-url": "http://www.example.com/blocklist",
"cache-size-mb": 2,
"dht-enabled": true,
"download-dir": "/c/media/",
"download-queue-enabled": true,
"download-queue-size": 5,
"encryption": 0,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/c/transmission/incomplete",
"incomplete-dir-enabled": false,
"lpd-enabled": false,
"message-level": 2,
"peer-congestion-algorithm": "",
"peer-id-ttl-hours": 6,
"peer-limit-global": 240,
"peer-limit-per-t0rrent": 60,
"peer-port": 57637,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": true,
"peer-socket-tos": "default",
"pex-enabled": true,
"port-forwarding-enabled": true,
"preallocation": 1,
"prefetch-enabled": false,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 2,
"ratio-limit-enabled": false,
"rename-partial-files": true,
"rpc-authentication-required": false,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "{b29293088014fae97e6ba2cc6953955d83d0a96aLdIhD5Ep",
"rpc-port": 9091,
"rpc-url": "/transmission/",
"rpc-username": "admin",
"rpc-whitelist": "*",
"rpc-whitelist-enabled": true,
"scrape-paused-t0rrents-enabled": true,
"script-t0rrent-done-enabled": false,
"script-t0rrent-done-filename": "",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 100,
"speed-limit-up-enabled": false,
"start-added-t0rrents": true,
"trash-original-t0rrent-files": false,
"umask": 0,
"upload-slots-per-t0rrent": 14,
"utp-enabled": true,
"watch-dir": "/c/transmission/watch-dir/",
"watch-dir-enabled": true
Model: RND2000v2|ReadyNAS Duo v2 Chassis only
Message 1 of 2
Space_Munky
Re: Transmission Web Interface won't work on ReadyNAS Duo v2
Is anyone able to help me with this please? I have no way to contact Customer Support as this product is 8 years old
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 748 views
  • 0 kudos
  • 1 in conversation
Announcements
