× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Turning on iSCSI after data on ReadyNAS4200
bwelmers
So I have a readyNAS 4200 that I have been using for a year or two. I have a LOT of data on it right now and I would like to try turning on iSCSI. So my question is "Can I turn on iSCSI without loosing all my data?"
At this point I am trying to make use of the ReadyNAS as a backup target and I would like to get more performance out of it then using the CIFS protocol.
Thank you for any replies
Message 1 of 9
mdgm-ntgr
NETGEAR Employee Retired
Re: Turning on iSCSI after data on ReadyNAS4200
If you enable iSCSI you can create targets using free space available on your data volume. Your data will remain intact.
Message 2 of 9
bwelmers
Thank you very much. It is just a little nerve wracking to make a change like that on the system with all the data sitting there.
Message 3 of 9
a_burger_with_f
When you are using the ISCSI it will allocate the space and view it as one big file so whatever you make the size of it, it will take that from the volume.
Agent ID: 82015 NETGEAR ReadyNAS Support Engineer
Contact Information: http://kb.netgear.com/app/answers/detai ... txaw%3D%3D
(US/Canada) 1-888-NETGEAR (Option 4 for Technical Support) / (UK) +44(0)8448 75 4000
Message 4 of 9
bwelmers
Thanks, I expected that part. It is just the current data side that I am/was worried about. Now to make the change and see how my backups work after that 🙂
Message 5 of 9
mdgm-ntgr
Now if you wanted to copy your data across to the iSCSI target you would need to copy the data across your network from the CIFS share to the mounted iSCSI target on your PC (a Windows Server perhaps?). You could share the data from that PC across your network.
Message 6 of 9
bwelmers
Nope, no need to move the files 🙂 all that I need is a good target for some Veeam backups. I am thinking that iSCSI would be quicker and better then the CIFS target that I am currently using. I am hoping for some better performance 🙂
Message 7 of 9
mangrove
Apprentice
My experience (and official performance numbers back this up) is that iSCSI is, like, 20-30% slower than CIFS. How did it go?
Message 8 of 9
bwelmers
I have not had the chance to move the files around at this point. We have not upgraded the SAN yet as a result we don't have space to move all the files over. Also there are a few other projects that need to happen before I can really play with the NAS and see how we can get things working better.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 7796 views
  • 0 kudos
  • 4 in conversation
Announcements
