Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
URGENT - Volume disappeared after adding new disk - 18837703
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-23
09:45 PM
2012-06-23
09:45 PM
ReadyNAS Pro Business Edition XRAID2
v4.2.20
4096Mb
Yesterday night I replaced an existing 1Tb drive with a new 2Tb drive. This is the 3rd of four drives I've been doing (with large gaps between each). Today I went to use the system and could not access any shares. When I logged into the NAS I got a scary message that the volumes could not be found. When I click the volumes tab, there are no volumes.
HELP please. I really need to get at this data, and while I have some backups, I'm not sure I've got 100% of everything. Not sure what the hell went wrong, the first two times I replace the drives went with out a hitch.
I've left everything along in the hope this might be any easy fix for a tech.
Thanks in advance, recent logs below.
Logs
Sat Jun 23 19:10:17 EDT 2012 System is up.
Sat Jun 23 19:10:17 EDT 2012 The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume. media MediaArchive backup
Sat Jun 23 19:10:04 EDT 2012 Volume scan failed to run properly.
Sat Jun 23 19:08:30 EDT 2012 Powering off device
Sat Jun 23 19:08:30 EDT 2012 Please close this browser session and use RAIDar to reconnect to the device after it is powered back on. System powering off...
Sat Jun 23 06:38:59 EDT 2012 System is up.
Sat Jun 23 06:38:59 EDT 2012 The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume. media MediaArchive backup
Sat Jun 23 06:38:44 EDT 2012 Volume scan failed to run properly.
Sat Jun 23 01:24:20 EDT 2012 RAID sync started on volume C.
Sat Jun 23 01:23:57 EDT 2012 Data volume will be rebuilt with disk 3.
Sat Jun 23 01:22:46 EDT 2012 New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 3]
Sat Jun 23 01:18:16 EDT 2012 A disk was removed from the ReadyNAS. One or more RAID volumes are currently unprotected, and an additional disk failure or removal may result in data loss. Please add a replacement disk as soon as possible.
Sat Jun 23 01:18:16 EDT 2012 Disk removal detected. [Disk 3]
Fri Jun 22 09:00:24 EDT 2012 System is up.
Thu Jun 14 21:44:40 EDT 2012 System is up.
Sun Jun 10 05:04:54 EDT 2012 The on-line filesystem consistency check completed without errors for Volume C.
Sun Jun 10 05:00:09 EDT 2012 The on-line filesystem consistency check has started for Volume C.
Sat Jun 9 17:15:35 EDT 2012 RAID sync finished on volume C.
Sat Jun 9 13:56:40 EDT 2012 System is up.
Sat Jun 9 13:56:35 EDT 2012 Data volume has been successfully expanded to 3687 GB.
Sat Jun 9 13:56:24 EDT 2012 Continuing with volume expansion or migration. Do not interrupt the system during this time. When complete, email notification will be sent to the alert contact list.
Sat Jun 9 13:54:24 EDT 2012 Rebooting device...
Sat Jun 9 13:54:24 EDT 2012 Please close this browser session and use RAIDar to reconnect to the device. System rebooting...
Sat Jun 9 07:14:32 EDT 2012 RAID scrubbing finished on volume C.
Sat Jun 9 06:25:01 EDT 2012 Volume C is approaching capacity: 80% used 572G available
Sat Jun 9 04:00:54 EDT 2012 RAID scrubbing started on volume C.
Fri Jun 8 17:09:05 EDT 2012 Found space that can be used to expand capacity, expansion process will start during next boot.
Fri Jun 8 17:08:04 EDT 2012 Found space that can be used to expand capacity, expansion process will start during next boot.
Fri Jun 8 17:07:20 EDT 2012 Found space that can be used to expand capacity, expansion process will start during next boot.
Fri Jun 8 17:07:04 EDT 2012 RAID sync finished on volume C.
Fri Jun 8 13:39:17 EDT 2012 RAID sync started on volume C.
Fri Jun 8 13:38:32 EDT 2012 Data volume will be rebuilt with disk 2.
Fri Jun 8 13:37:19 EDT 2012 New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 2]
Fri Jun 8 13:36:09 EDT 2012 If the failed disk is used in a RAID level 1, 5, or X-RAID volume, please note that volume is now unprotected, and an additional disk failure may render that volume dead. If this disk is a part of a RAID 6 volume, your volume is still protected if this is your first failure. A 2nd disk failure will make your volume unprotected. If this disk is a part of a RAID 10 volume,your volume is still protected if more than half of the disks alive. But another failure of disks been marked may render that volume dead. It is recommended that you replace the failed disk as soon as possible to maintain optimal protection of your volume.
Fri Jun 8 13:36:09 EDT 2012 Disk failure detected.
Fri Jun 8 13:35:53 EDT 2012 A disk was removed from the ReadyNAS. One or more RAID volumes are currently unprotected, and an additional disk failure or removal may result in data loss. Please add a replacement disk as soon as possible.
Fri Jun 8 13:35:53 EDT 2012 Disk removal detected. [Disk 2]
v4.2.20
4096Mb
Logs
Message 1 of 5
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-23
09:50 PM
2012-06-23
09:50 PM
Re: URGENT - Volume disappeared after adding new larger disk
Please contact NetGear tech support (http://www.readynas.com/support). Edit the thread title (i.e. subject of first post in the thread) to include your case number.
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-23
09:55 PM
2012-06-23
09:55 PM
Re: URGENT - Volume disappeared after adding new disk - 1883
done. 🙂
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-24
08:36 PM
2012-06-24
08:36 PM
We need log in the system and do further checking.
So please boot the device to "Tech support" mode and forward the port 23 for us.
After that, PM me the remote access host address, you also can post the remote host address into case.
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-26
12:38 AM
2012-06-26
12:38 AM
Please normal boot the system. It should work fine.
Message 5 of 5
