- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ultra 6 plus - SMB not advertised anymore
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
ULTRA6 PLUS 6x3TB Xraid2 OS 4.2.28 36% capacity used
Suddenly the SMB shares are no more showing on the windows clients - not related to 4.2.28 upgrade.
Shares are still accessible via the IP address, SSH works.
No mods were done recently, all disks are fine.
Maybe the CIFS service is not running ? Some partitions get full ?
I spent hours around this and can work my way around Windows and networking but would need pointers for Linux and such.
Any ideas ?
Thanks
Benoit
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
1) in /etc/var/log/samba/log.nmbd
nmbd version 3.6.25 started.
Copyright Andrew Tridgell and the Samba Team 1992-2011
standard input is not a socket, assuming -D option
invalid permissions on socket directory /var/nmbd
ERROR: nb_packet_server_create failed: NT_STATUS_UNSUCCESSFUL
2) Change the permissionto 755 (it already was but probably a 'glitch' happened)
3) Restart nmbd
NAS:/etc/samba# nmbd -i
YES ! Thank you Google and a few hours of time...
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ultra 6 plus - SMB not advertised anymore
You are saying that \\nasipaddress\sharename works?
If so, what exactly is failing? Just the appearance of the NAS in the file explorer left pane? Or something else?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Yes, the name is not recognized anymore. I thought I got access via IP but in fact not.
Admin & shares are accessible (shares is empty). And Other folders not accessible.
I have SSH & Frontview.
Maybe some service not running ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Log in with ssh, and check the fullness of the OS partition
df . -h
df . -i
- Mark as New
- Bookmark
- Subscribe
- Permalink
With the SSH GUI, I can browse thru directories. I could download a file - data is still there.
NAS:~# df . -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/md0 65536 30075 35461 46% /
NAS:~# df . -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 1.4G 2.5G 36% /
NAS:~#
NAS:~# df -h
tmpfs 16K 0 16K 0% /USB
/dev/c/c 11T 3.9T 7.0T 36% /c
/c/home 11T 3.9T 7.0T 36% /home/ftp/homes
/c/Dropbox 11T 3.9T 7.0T 36% /home/ftp/Dropbox
/c/cams 11T 3.9T 7.0T 36% /home/ftp/cams
/c/medias 11T 3.9T 7.0T 36% /home/ftp/medias
/c/partage 11T 3.9T 7.0T 36% /home/ftp/partage
/c/utilisateurs 11T 3.9T 7.0T 36% /home/ftp/utilisateurs
NAS:~# df -i
tmpfs 255677 1 255676 1% /USB
/dev/c/c 182683648 537274 182146374 1% /c
/c/home 182683648 537274 182146374 1% /home/ftp/homes
/c/Dropbox 182683648 537274 182146374 1% /home/ftp/Dropbox
/c/cams 182683648 537274 182146374 1% /home/ftp/cams
/c/medias 182683648 537274 182146374 1% /home/ftp/medias
/c/partage 182683648 537274 182146374 1% /home/ftp/partage
/c/utilisateurs 182683648 537274 182146374 1% /home/ftp/utilisateurs
NAS:~#
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your OS partition is not full, so that cause is ruled out.
Can you see the files with FTP?
Did you try restarting the NAS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, which version of Windows are you running on your client machines?
Is the NAS in the same workgroup as your client machines?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
- I can see the files with FTP
- The NAS was rebooted a few times
- It is in the same workgroup
- The client PCs are WIN7 and WIN10 (tried 3 of them)
- Streaming devices (DLNA players) do not see the NAS anymore either
I controlled the parameters
- CIFS protocol is selected
- The shares are defined, with CIFS enabled
- Shares are not made invisible
What puzzles me is that it was running fine a few days ago.
I noticed it becoming slow/unstable while listening to some music - I did not investigate.
The next day, no shares anymore.
There were no changes in configuration (NAS or Network) during this period.
During early troubleshooting, I noticed that I lost SSH access. I noticed there was a better OS release and upgraded (using Frontview) from 4.2.27 to 4.2.28 and was happy to have SSH again.
Add-ons work OK (Dropbox, Tonido..). I can also see the files from Tonido.
Can I check some logs somewhere or if some 'share' service is running ?
Tx 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Per-incident netgear support is the fastest way to get it sorted.
You could perhaps try toggling CIFS off/on on the services->standard file protocol page, and checking that it is enabled for each share on the share list. You could also reset the owner/group for each share on the advanced options page.
An OS reinstall is another possibility - it will reset the admin password to "netgear1" and the NAS network configuration to dhcp.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I found in the journal 'An error occured when starting the CIFS service' !
Mon Dec 21 12:45:00 CET 2015 Une erreur est survenue lors du démarrage du service CIFS.
Where should I go to have more details ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@benoitmabille1 wrote:
OS reinstall : I fear a little bit that my add-ons will not survive it
They should.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is an error message in the log hat an error occurs when starting the CIFS service !
I would feel more reassuring to attempt this troubleshooting first 🙂 Any idea where a detailed log would be ?
Tx
- Mark as New
- Bookmark
- Subscribe
- Permalink
3) Restart nmbd
