Orbi WiFi 7 RBE973
Reply
Ultra Plus Upgrade from Beta 6.1.9 to Release 6.1.9
CharlesR
Guide
I just downloaded and rebooted the release firmware from the latest beta and the unit appears to be working away but it's not found on the network. My Wake On Lan utility reports it being offline. Should it take more than a few minutes to upgrade? If not, any suggestions?
Message 1 of 18
Guru
Re: Ultra Plus Upgrade from Beta 6.1.9 to Release 6.1.9
Mine took less than 5 minutes. How long has it been booting?
Message 2 of 18
CharlesR
Guide
Longer than that... I can hear the disk being accessed and the LAN light(s) flash a touch. I installed RAIDar and it doesn't find it either.
The disk activity winks once in a while for a short period of time and the NIC flashes in short bursts almost as they are in a loop per se. Their activity never seems to vary...
Message 3 of 18
mdgm-ntgr
NETGEAR Employee Retired
Has it booted yet?
If not, put the NAS in tech support mode, let me know your agreement to http://kb.netgear.com/app/answers/detail/a_id/20932/~/netgear-remote-access-policy and let me know the 5-digit port number e.g. via PM.
Message 4 of 18
CharlesR
Guide
I don't know if it ever rebooted as it's in the other room and I wasn't watching. Now the NIC light is pretty much flashing non-stop so it appears something is going on...
Message 5 of 18
mdgm-ntgr
Can you ping it?
Can you SSH to it (if you enabled SSH)?
Message 6 of 18
CharlesR
Guide
Can't ping it.
Message 7 of 18
mdgm-ntgr
Which model is this? If it is a 4-bay or 6-bay then looking at what is on the display on the front of the NAS would be helpful.
Edit: Oops. I see by searching through your posts you have a legacy 2-bay.
Message 8 of 18
CharlesR
Guide
Yep.. a Ultra Plus 2 bay. Where do I find the port number? And which lights are for service mode?
Message 9 of 18
mdgm-ntgr
See http://kb.netgear.com/app/answers/detail/a_id/21100
The 5-digit port would show in the Info (far right) column in RAIDar when booted into tech support mode.
Message 10 of 18
CharlesR
Guide
OK... going to put in service mode now...
Message 11 of 18
CharlesR
Guide
I just PMed you the code.
Thanks. If you like I could give you a phone number... just PM me.
Message 12 of 18
mdgm-ntgr
Don't think I could see anything wrong apart from some issues that suggested there may be a network problem.
If it doesn't come up right perhaps we can try Teamviewer.
Message 13 of 18
CharlesR
Guide
Just came up fine... looking around. From the log it appears it rebooted fine during the upgrade...
Fri Sep 19 2014 20:10:38
System: ReadyNASOS background service started.
Fri Sep 19 2014 20:08:25
System: The system is rebooting.
Here's where you rebooted it...
Fri Sep 19 2014 21:47:47
Fri Sep 19 2014 21:47:46
System: ReadyNASOS service or process was restarted.
I presume using a fixed IP wouldn't matter... what type of network issue(s) did you see? If it would help in anyway I could retry the upgrade again... if it's perhaps a generic issue not unique to me.
And I much appreciate you taking a look!
Message 14 of 18
mdgm-ntgr
It couldn't find the apt archive which sounds like a DNS or Gateway issue.
Message 15 of 18
CharlesR
Guide
If it helps it has a fixed IP address off of a switch then a DD-WRT router (doing DHCP) which is connected to a Internet gateway/router.
I think I can handle your PM. Thanks again.
Message 16 of 18
mdgm-ntgr
I probably should have suggested simply doing a reboot initially. When a NAS gets stuck during an upgrade sometimes a reboot fixes it.
Message 17 of 18
CharlesR
Guide
It appears to be working great. Accessed it today for several hours without a issue. I appreciate you taking a look... hopefully I'll be getting a Pro before long. For some reason I enjoy playing around with these older models.
Message 18 of 18
Top Contributors
Discussion stats
  • 17 replies
  • 2544 views
  • 0 kudos
  • 3 in conversation
Announcements
