× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Uncontrolled power-ups with RN Pro after Raidar Upg.
jewelryab
Re: Uncontrolled power-ups with RN Pro after Raidar Upg.
Now with the current firmware after a few minutes of shutting down, it turns itself back on. The WOL is not enabled.
Message 51 of 57
tark
Tutor
support is their any update on this issue ?
Message 52 of 57
tark
Tutor
bump
Message 53 of 57
Jedi_Knight
Tutor
Please contact support and open the case if you are having issue with current 4.2.17 release.
Message 54 of 57
Jedi_Knight
Tutor
Tark,
We will get this fix in next release. Thanks.
Message 55 of 57
BotanyBay
Tutor
I just received an RMA unit for a different problem and the new unit has this issue. it always boots when power is first applied and if i turn it off with two presses of the blue button it comes back up in about 4 minutes.
I put in a single spare disk - updated the firmware to 4.2.17 which is what i was using before - powered down - installed 6 disks and it came right up. however unit will not stay powered off more than 5 min before reboot.
this is second rma
- original unit stuck not finding disks and saying readynas
- first rma temp 2 sensor went to 190F during weekly parity scrub of raid but normal otherwise probable thermal grease issue
- second rma arrived with 4.2.12 firmware (if memory serves) so flashed to 4.2.17 with spare disk but will not stay powered off
any suggestions? this is a pro business edition.
Message 56 of 57
BotanyBay
Tutor
Ended up with a new unit, everything is working well at this point! Thanks for the support!!!
Message 57 of 57
Top Contributors
Discussion stats
Announcements
