× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Update SLL
ncameron
Update SLL
I have happily and successfully run the Logitech Media Server sofware on my ReadyNAS 314 for many years.
In the lastest update (LMS 8.2.0) I am having problems with the interface - the additional LMS Apps, such as Spoty for Spotify,  are not visible.
The LMS guru Michael Herger is saying that this is becvause I am running an obsolete bersion of SSL on the RN314, 2.002 to be precise.
I have tried to reinstall / update Perl SSL on my ReadyNAS 314 using PuTTY with the commands:
apt-get update
apt install libio-socket-ssl-perl
It appears to succeed but I still SSL version 'IO::Socket::SSL: 2.002'
Does anyone know how to get a more recent version of SSL on a ReadyNAS 314?
Model: RN31441D|ReadyNAS 300 Series 4- Bay (4x 1TB Desktop)
Message 1 of 4
Marc_V
NETGEAR Employee Retired
Re: Update SLL
@ncameron
The current Debian version running on ReadyNAS is Debian 9 in which libio-socket-ssl-perl 2.002 is the latest it is supporting, this might explain why the package update is still showing SSL: 2.002. An option would be to build the latest version of the libio-socket-ssl-per package.
Here are some links that may help you with if you plan to rebuild the libio package to get a higher version than 2.002
Source code
Guide on creating and setting up environment to build the libio-socket-ssl-perl package
Other users may be able to help and chime in and share.
Hope this helps!
Model: RN31400|ReadyNAS 300 Series 4- Bay (Diskless)
Message 2 of 4
ncameron
Re: Update SLL
I really appreciate the help, but that documentation goes way over my head.
Is there an instruction set for dummies?
Message 3 of 4
ncameron
Re: Update SLL
I managed to do all that, and I have an updated SSL - BUT my ReadyNas will no longer connect to the outside world.  It has an internal IP address, and I can see it though my browser, but it says it is unable to obtain an IP address, and does not see the Internet.
Any ideas?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1287 views
  • 1 kudo
  • 2 in conversation
Announcements
