Orbi WiFi 7 RBE973
Reply
Updating Readynas Pro to Latest Firmware
McRob1
Luminary
I am currently running OS 6.6.1 on a legacy readynas Pro 6.  When I do a check for updates it tells me that I am already running the latest firmware even through firmware viersion 6.7.1 is available.  Do I need to do a manual update of the firmware to get 6.7.1 installed?
Model: ReadyNAS RNDP6620|ReadyNAS Pro 6
Message 1 of 11
Accepted Solutions
Guru
Re: Updating Readynas Pro to Latest Firmware
@McRob1 wrote:
Must be a screen that someone forgot to change when creating the new firmware.
Might be your browser cache too.
Message 10 of 11
All Replies
jak0lantash
Mentor
The update server may not be advertising the latest version yet. NETGEAR often waits some time between the moment the firmware is available for download and its addition to the update server. They also may prompt for the update by waves. You can always download it and install it "manually".
Message 2 of 11
Guru
Netgear always starts by releasing the firmware for manual installation first, and then posts it to the update server in a week or so.
You can either install it manually now or you can wait for it to show up in check-for-updates.
Message 3 of 11
McRob1
Luminary
I got a automatic notice when I logged into my NAS516 and my NAS628.
When I logged into my NASPRO I did not get a notice.
Even when I selected update firmware it said I was already running the latest firmware which was 6.6.1.
I thought that the legacy NAS units that were running firmware 6 and above were supposed to update the same as newer NAS units.
I guess not.
Model: ReadyNAS RNDP6610D|ReadyNAS Pro 6
Message 4 of 11
Guru
It  does.
Is the Pro using a static IP address, or is it configured with DHCP?
Message 5 of 11
McRob1
Luminary
It is DHCP.
Model: ReadyNAS RNDP6610|ReadyNAS Pro 6
Message 6 of 11
Guru
Then it is odd that the pro isn't seeing the update.  Perhaps wait a day and try again.  I suspect there is a cluster of servers, and they might not be always in step.
Message 7 of 11
Sandshark
Sensei
None of my legacy units are showing the 6.7.1 update, either.  The ones running 6.6.0 are showing the 6.6.1 update.  If it's somehow done in "waves", how does it differentiate?   I updated my sandbox unit manually to 6.7.1.
Message 8 of 11
McRob1
Luminary
I updated the unit manually and it seems to be working.
One thing I did notice is when loging into the admin screen all units still show version 6.6.1 but after you get logged in it shows 6.7.1.
Message 9 of 11
Guru
Message 10 of 11
McRob1
Luminary
Cleared the browser cache and corrected the issue.
Thanks
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 4442 views
  • 0 kudos
  • 4 in conversation
Announcements
