- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Upgrade files to go from 4.2.31 toOS6 on a Ultra?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am looking for the files to upgrade an Ultra 6 to OS6. None of the links in previous threads work.
TIA
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Upgrade files to go from 4.2.31 toOS6 on a Ultra?
@bstuke wrote:
@Marc_V That worked, thanks.
Working links are also here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-R4toR6-download-links/m-p/...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe you also wish to check if the bios is up to date (which needs to be updated separatly and didn´t comes with the firmware upgrade!). I performed that after the OS6 upgrade (from 4.x) which solved some issues for me. So you might try to wish to do the same. The URL I used for the ReadyNAS Bios Upgrade process is: https://www.admin-enclave.com/en/articles/linux/484-upgrade-the-bios-from-an-readynas-device.html
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's simpler just to download http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin and install it as an add-on. This should be done before you convert the NAS to OS-6.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The linked process is only applicable to units already converted to OS6 and is out of date since it's adding a Debian Wheezy repo but ReadyNASOS6 is now based on Debian Jessie.
As @StephenB says, it is far easier to use the update add-on while still running OS 4.2.x. In fact, I used a spare drive to downgrade one of my Pro units to 4.2.x and then did the BIOS update, then went back to OS6 rather than go through the process listed there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for all the feedback.
Current situation:
System is running 6.10.2
BIOS info:
/sys/class/dmi/id/bios_date
06/10/2010
/sys/class/dmi/id/bios_version
080016
The systems seems to be running fine. Backup is working properly, alerts are working properly. I am not trying to do anything fancy, it is simply a storage repository for raw images and video.
Should I upgrade the BIOS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
