Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Upgrade from ReadyNAS Duo to Ultra 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-20
08:25 PM
2011-07-20
08:25 PM
I currently have a ReadyNAS Duo with two Seagate ST31500341AS 1.5TB drives installed. I'm at 75% capacity, so am thinking about upgrading. What would be the recommended procedure to upgade to a ReadyNAS Ultra 2, so that I might install larger hard drives down the road. Can I just move the disks and all my data will be intact? (It can't be that simple..)
Also, need to go to OS X Lion for software, so would like to get Time Machine back as well.
Thanks!
Thanks!
Message 1 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-20
08:29 PM
2011-07-20
08:29 PM
Re: Upgrade from ReadyNAS Duo to Ultra 2
You can't migrate your disks across from a Sparc ReadyNAS (e.g. Duo) to an x86 ReadyNAS (e.g. NVX, Ultra, Pro). See http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
You'll need to transfer your data e.g. across your network.
There will be an update to Sparc ReadyNAS adding Mac OS X Lion support so you may not need to upgrade to an x86 ReadyNAS yet.
x86 ReadyNAS have Mac OS X Lion support in RAIDiator x86 4.2.18 (or later).
Welcome to the forum!
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-20
08:35 PM
2011-07-20
08:35 PM
Thanks for the link.
I realize that Lion support for the Duo will come, but my thinking is that I'm going to need the space sooner rather than later, so maybe now is the time...Especially since the Duo is now the more dated of the two products.
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-20
08:38 PM
2011-07-20
08:38 PM
Well yes, it could be the time now.
I'd buy new disks from the HCL
Put one disk in the ReadyNAS, update to 4.2.18, then power down, put all the disks in and do a factory reset via the Boot Menu (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu)
Edit: Personally I'd recommend getting a 4-bay ReadyNAS or a 6-bay, not a 2-bay. You don't need to fill it now. You could start out with a couple of disks and add more later.
Message 4 of 4
