- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Upgrading Netgear ReadyNAS Disks
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried to increase capacity in my RN214 (firmware 6.9.3) from 4 x 3TB to 4 x 10TB.
I replace the drive one at a time and let them sync before changing the next. All went well until I replaced the 4th disk when the NAS created 2 RAID groups.
RAID group #1 seems to be using all 4 disks but RAID group #2 only shows the first 3.
Total capacity of the NAS is 20TB not the 30TB as expected.
I can still access all my data but how can I get back to a single RAID with 30TB?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Upgrading Netgear ReadyNAS Disks
With vertical expansion, the NAS would always create a second RAID group. However, with XRAID it wouldn't be shown on the volume page.
Are you currently in XRAID or FlexRAID? If you are in XRAID you will see a green stripe on the XRAID control on the volume page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What does your mdstat.log look like?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm sure it was on X RAID but it's now showing as RAID 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
X-RAID uses RAID-5 for 3 or more disks in the RN214 by default. As StephenB mentioned Its whether you see the green stripe or not that tells you whether you're using X-RAID.
Look in mdstat.log and you'll see
md126 : active raid5 sdb4[2] sda4[1] sde4[0]
13672082432 blocks super 1.2 level 5, 64k chunk, algorithm 2 [3/3] [UUU]
So there's no sdd4 in md126
Look in partitions.log and we see that sdd4 doesn't exist
8 64 9766436864 sde
8 65 4194304 sde1
8 66 524288 sde2
8 67 2925545912 sde3
8 68 6836172304 sde4
8 0 9766436864 sda
8 1 4194304 sda1
8 2 524288 sda2
8 3 2925545912 sda3
8 4 6836172304 sda4
9 126 13672082432 md126
8 16 9766436864 sdb
8 17 4194304 sdb1
8 18 524288 sdb2
8 19 2925545912 sdb3
8 20 6836172304 sdb4
9 1 523712 md1
8 48 9766436864 sdd
8 49 4194304 sdd1
8 50 524288 sdd2
8 51 2925545912 sdd3
If you look in disk_info.log you'll see that disk sdd is in channel 3 (if counting 0 to 3, it would be in drive bay 4 if counting from 1-4).
You should try a reboot and see if a resync starts.
Failing that there's a few options:
1. Remove disk 4 and reinsert it to trigger a resync and hopefully the addition of partition 4, adding it to md126.
Or 2. I could add partition 4 to that new disk and manually add it to md126. Once the sync completes (this will take a while) the volume should then expand.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The sync has started. This will take several hours, perhaps a few days or so. After the sync completes the volume will then expand.
- Mark as New
- Bookmark
- Subscribe
- Permalink
