× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Upgrading capacity
karl_w_w
Upgrading capacity
I currently have 3 x 3TB drives (6TB capacity) using X-Raid and I'm running out of space. My plan is to add a 6TB drive to give myself 3TB more total capacity, so that in the future I can replace one of the 3TB drives with another 6TB to increase total capacity by 3TB again.
Am I correct about these increases and does it seem like a sensible plan? Thanks.
Model: RN104|ReadyNAS 100 Series
Message 1 of 3
Accepted Solutions
Guru
Re: Upgrading capacity
Yes.  The capacity rule is "sum the disks and subtract the largest".
  • 3x3 TB -> 9 TB - 3 TB = 6 TB volume size
  • 3x3 TB + 6 TB -> 15 TB - 6 TB = 9 TB volume size
  • 2x3 TB + 2x6 TB -> 18 TB - 6 TB = 12 TB volume size
It is sensible, though as you already know you'll need to wait a while to get the full benefit of the first 6 TB drive.
Message 3 of 3
All Replies
Retired_Member
Not applicable
@karl_w_w, You might want to go here to explore on your own what you will get.
http://rdconfigurator.netgear.com/raid/index.html
kind regards
Message 2 of 3
Guru
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 725 views
  • 2 kudos
  • 3 in conversation
Announcements
