× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Upgrading one of HDD to 4TB drive
microB
Hi,
I was running 2x2TB JBOD formatted disks configuration in ReadyNAS Duo V2. I upgraded one of the disks to 4TB, but ReadyNAS created only 2TB volume.So, total capacity remained the same 4TB, I expected it to be 6TB. What can I do to use extra 2TB from my new HDD?
RND2000-200EUS
RAIDiator 5.3.13
HDDs:
WDC WD20EARS-00MVWB0 1863 GB
ST4000DM004-2CV104 3726 GB
Model: ReadyNAS RND2000v2|ReadyNAS Duo v2 Chassis only
Message 1 of 4
Guru
Re: Upgrading one of HDD to 4TB drive
Do you only have a single C volume, or do you have both a C and a D volume?
Message 2 of 4
microB
I have both C and D. Both of them are displayed as 1.81TB
Message 3 of 4
Guru
I don't own the v2, so I don't have direct experience with it.
You could try creating the volume again.  If that gives the same result, you might need to do a factory reset.
Are you familiar with the linux CLI?  If ssh is enabled, you could use the linux command line to expand the file system on the volume.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 667 views
  • 0 kudos
  • 2 in conversation
Announcements
