- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Using X-RAID To Reformat Disk for more Storage, Is this the best solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Before I complete this task, just wanted to get feedback if this the best, easiest wayto backup my data.
Currently, I have 4 disck in my NAS. (2) 2TB & (2) 1 TB drives.
The 2TB drives were setup as redundant stoage. Meaning Drive 1 has data a-z and drive 2 has data A-Z.
Drive 3 & $ with lesser space was setup the same way.
The problem now is my la[top drive is bigger than my backp NAS (4TB) on the lap.
Give this situation should all the disk in NAS be setup for X-RAID? or Maybe this is the definition of Flex-Raid, where I pair a 2TB with a 1 TB in the NAS. and having two backups for 3 TB each.
My total backup requirements from the Laptop is about 2.3 TB.
What are your suggestions.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Using X-RAID To Reformat Disk for more Storage, Is this the best solution?
I don't really understand what you are trying to say. Do you have 4 volumes (one per disk) or do you have two RAID-1 volumes (one per disk pair)? Also what ReadyNAS model do you own, and what firmware is it running?
If you have a NAS that is running 4.2.x, 5.x or 6.x firmware, then xraid would give you 4 TB of total storage with this combination of disks.
But if you have a NAS that is running 4.1.x, then you'd only get 3 TB - you'd have to upgrade the two 1 TB drives to 2 TB ones to maximize space (which would give you 6 TB).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Currently, I have 4 indiviual volumes. Each volume is a complete backup of the laptop. Overkill, I know.
what I would like to do - and it seems your suggestion states I can - pair a 2TB & 1TB = 3 TB and then pair the other 2TB & 1 TB drive to make a second backup. That's what I would like to do...
Last, if i do go the X-Raid method do I have to reformat all of the drives?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, that helps. What ReadyNAS model do you have?
I think the answer to that depends on which ReadyNAS you have. I believe that RAID-0 requires the disks to be the same size (data is striped across the drives). jbod is an option on OS 6 NAS and should be able to aggregate two drives of unequal size. Either way the two volumes are fragile - if either drive fails you lose the data on both. It's not a configuration I recommend.
Any change to your current volumes will destroy the data on the volumes you change. One way to switch to XRAID is to do a factory default procedure from the ui.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update.
First I have the RN104, v6.6.0 os.
Did a factory reset... but I don't see the entire storage.
I put the 1 tb in disk 1! 1.5tb in disk 2 and 2tb in disk 3 & 4. My total shows 4tb. Not the 6.5 I was expecting. My understanding is the drives have to be equal or greater than disk 1.
Last, I w under the impression that after facto reset, I would be given the option to chose x-raid.
Before I start backing up is there a way to see / add the remaining 2.5 tb
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
First: The capacity rule for XRAID single redundancy is "sum the disks and subtract the largest". That works out to 4.5TB, not 6.5TB. The remaining space is needed for parity blocks that give you redundancy when a disk fails.
Second: The NAS displays space in TiB (though it labels it "TB"). 1 TiB = 1024*1024*1024*1024 bytes; 1 TB = 1000*1000*1000*1000 bytes. 4.5 TB is the same as 4.09 TiB. There's a bit more overhead, and I think the NAS rounds down.
So 4 TiB is what you should be seeing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Beluna,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
