× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Using one UPS with an NV+ and an NV+ v2
PerBKWine
Tutor
I recently bought my second NV+, this time a ReadyNAS NV+ v2, to add to the one I have which is NV+ (not v2).
I also have an APC UPS pack ES 550.
I have connected the NV+ v2 to the UPS and it recognises the UPS without problem. So this is the Master, from a UPS standpoint.
I now want to make the "old" NV+ a UPS Slave from the Master and try and do this by going to Frontview Power > UPS Configuration and select "Enable monitoring of UPS physically attached to a remote ReadyNAS" and enter the IP address of the Master (the NV+ v2).
(Both are connected directly to the UPS; are on the same network over a Netgear bridge; and have fixed IP addresses defined by the Netgear router/cable modem)
I then get an error message: "Could not connect to the specified UPS server. Please verify that UPS sharing is enabled on that system and try again".
However:
On the Master NV+ v2 I can find no such "UPS sharing" setting. Actually, there are no configuration at all for the UPS on the NV+ v2. (And if I want to do it the other way around, setting the old NV+ as UPS Master and the NV+ v2 as Slave that seems not possible either, there is no setting for the NV+ v2 to use another server as master.)
What do i need to do to share the same UPS between the NV+ and the NV+ v2? Or is that impossible?
-Per
Message 1 of 19
mdgm-ntgr
NETGEAR Employee Retired
Re: Using one UPS with an NV+ and an NV+ v2
I don't think is currently possible with the v2, certainly not via the UI. It is a feature I would like to see added.
Message 2 of 19
PerBKWine
Tutor
Isn't that strange!! So I would need to have one UPS per file server then...
Message 3 of 19
Caustic
Is there any news on this? To me, it is a huge feature that is missing. Is it possible to configure it via the command line?
Message 4 of 19
Caustic
I was going to plug the USB cable into the NV+ v1 as that has far more on it atm. I will try that tonight, looks good, should be at least enough to let me figure it out. Thanks and thanks again.
Message 5 of 19
mdgm-ntgr
I tried what I thought might work, but it didn't. I think we need to wait for the feature to be added hopefully in a future firmware update.
Message 6 of 19
Caustic
So just to confirm, there is no way to currently get it to work using either as the master?
Message 7 of 19
mdgm-ntgr
There's probably more to it than that. You might need to read up on configuration of NUT. If you find a solution post it here.
Message 8 of 19
Caustic
I (think) have got my v2 connecting to the UPS server on the v1. The config system is messy but I'll keep working on it.
Message 9 of 19
Marto731
To Caustic & previous posters
From an electrical viewpoint, I am not happy about putting the 2 NAS's off the same UPS.
ES550 refers to 550VA, or 330Watts.
I would like you to pull out the mains 120V /230V feed to UPS, and simulate how much run time you have. :idea:
For one NAS you may have 10mins. For 2 NAS you may have 4 mins.
http://www.apc.com/resource/include/tec ... u=be550-fr
Is that enough time, to save and close your applications before powering down?
Regards, Marto,
Netgear Tech support
Message 10 of 19
Guru
The way I read the chart you would get about 40 minutes for 1 NAS (50 watt load) and 21 minutes for 2 NAS (100 watt load). That is using the "typical" power numbers from the comparison chart for the NV+ v2. http://www.netgear.com/images/ReadyNAS_ ... -57079.pdf.
Message 11 of 19
Caustic
I have not tried pulling the plug with 2 NAS's yet and letting the battery run out, but with one it started the power down at 70% which was after 5 mins of battery time. I don't expect to keep using them when the power goes, I would want both to shut down asap. Besides, I get the same figures as StephenB, I am assuming that each NAS will pull 60W tops. Some HDDs use more than others so giving a bit of leeway. Also, the switch needs to be on the UPS as well, obviously, so that adds a few more watts. At 130W all in, it says 16mins. As far as I can see, that should be fine? Or have I missed something? There is no PC attached to the UPS. I don't care about my PC, only my ReadyNAS. 🙂
Just double checked, V2 is connected to V1. Variable changes on V1 are reported on V2. I set the V1 to shutdown at 90% battery and I pulled the plug. V1 started shutdown after 2 mins, and shutdown within 2 mins. However, the V2 didn't budge, even though it correctly knew it was running on battery power. Ideas? Is there a way I can send a test signal? What should the shutdown command be?
Message 12 of 19
Guru
I don't have a V2, but I am thinking that for this to work the V1 shutdown threshold needs to be significantly longer than the V2 (so the V2 always reaches its threshold before the UPS server on the V1 shuts down).
BTW, I use a similar setup with my duo and nv+ (both v1) - they are my backup NAS. The Pro has its own UPS.
We had severe thunderstorms yesterday, with several momentary outages followed by lost power for a couple of hours. Investing in a UPS is definitely a good idea!
Message 13 of 19
Caustic
I couldn't agree more about an UPS being a good idea. Such a shame the v2 doesn't have the feature built in.
The v2 shouldn't have a shutdown threashold, surely. The V1 (the one monitoring the UPS, the master) should, then it hits the value set, it tells the other devices (the slaves) to shutdown. The spec says that the master will wait for all slaves to disconnect before it continues. But I will have to double check the logs to find where the system went wrong. I think I am getting a little out of my depth!
Message 14 of 19
Caustic
An update, I have found the command to send a test shutdown signal "upsmon -c fsd" and that worked. SSH into the V1, typed that, and both NAS and my PC (which I accidently had connected as well using WinNUT) all shutdown within a minute.
So, why doesn't pulling the power cable out work? Why does the V1 switch off, but the V2 just keep going?
Message 15 of 19
PerBKWine
Tutor
@ Caustic (& others)
How did you set it up with the V2 as a slave to the V1 (even if it does not work)? Perhaps I can test it here and see if works for me.
For me, the time to shut down would be sufficient for the two units. I'm not running any critical application that requires a lot of time to end. But I do have very important data on the disks that needs to be shut down properly.
(this is one of these hidden (non)features that would have made me think twice before choosing a V2... Hope it will be part of a firmware upgrade sometime.)
Message 16 of 19
Caustic
It was quite easy, the V1 can be set up as the host just fine in Frontview. I then got WinNUT to run on my PC so I could test the settings.
I used the guide here: http://buffalo.nas-central.org/wiki/Ins ... _%28nut%29
There is no need to install anything, as it is already there. Near the bottom of that link is "Setting up NUT and WinNUT clients", that is where to start. The correct line is:
MONITOR UPS@192.168.1.76 1 monuser pass slave
The frontview system doesn't let you change the username and/or password, so they are always the same.
DISCLAIMER: I am a real newbie at all things linux/unix and learning via trial and error.
CD
PS. If you can test it and see if it works for you, that would be fantastic.
Message 17 of 19
PerBKWine
Tutor
Thanks. Not sure when I'll have the chance to do it. Let's hope for a firmware upgrade that takes care of it!!
Message 18 of 19
Caustic
Just a super quick post to say how glad I am that the latest NV+ v2 firmware features much improved UPS support. Super easy to update firmware and my v2 now monitors the UPS attached to my v1 right from the built in UI.
.. However, I haven't tested it ... must try that, just to be sure!
CD
Message 19 of 19
Top Contributors
Discussion stats
  • 18 replies
  • 2995 views
  • 0 kudos
  • 5 in conversation
Announcements
