Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Verification of ReadyNAS Duo Disk Upgrade Procedure
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-28
06:33 AM
2011-07-28
06:33 AM
Hi All...
Just want to verify the proper way to upgrade my Duo.
Current Config:
Model: ReadyNAS Duo [X-RAID]
Firmware: RAIDiator 4.1.7 [1.00a043]
Memory: 256 MB [2.5-3-3-7]
Volume C: Online, X-RAID, Single disk, 73% of 461 GB used
I'm getting ready to put two 1-TB disks in. My understanding is that this is the procedure I should use to retain my data:
1) Install a single 1-TB disk in the open slot (this can be hot-swapped).
2) Wait until the data is replicated (could take anywhere from 30 min, to 12 hours - more the later given the amount of data I have)
3) Once replicated, remove the 500 GB disk, and replace with second 1-TB disk (can this be hot as well, or is a shutdown required?)
I just want to make sure the above steps are correct.
Thanks!
Max
Current Config:
Thanks!
Max
Message 1 of 5
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-28
06:42 AM
2011-07-28
06:42 AM
Re: Verification of ReadyNAS Duo Disk Upgrade Procedure
Correct (hot swap is the way to go)
Also - you may have missed Step 0) Backup your data to an external drive (ie no point taking unnecessary risks, however minor)
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-28
06:54 AM
2011-07-28
06:54 AM
Awesome point! As far as backups are concern, should I use an external USB drive, or should I put it temporarily on my machine (provided I have the drive space)?
Thanks for the help!
Max
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-28
07:01 AM
2011-07-28
07:01 AM
Whichever is most convenient
However, your reference to 'temporarily' copying the data to your PC suggests you are not already backing up your NAS. I would recommend investing in an external USB drive and using that - not just for the upgrade but for regular backups afterwards - as a very low cost way to further secure your data
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-28
07:22 AM
2011-07-28
07:22 AM
If you ever have any problems with the NAS, the backup is your data's life preserver. Never ever trust critical or important data to only one device. When I copy photos from my camera to the NAS, I wait until a backup has been performed before erasing them from the camera. An NAS no matter how many drives, no redundancy, single redundancy or dual redundancy is still just one device. Upgrades of the OS, and drive addition or replacement is when the array is most vulnerable. The resync process puts a lot of strain on all the drives because they are working hard for hours at a time.
If you ever get yourself into the position of adding a second ReadyNAS, the best backup device for a ReadyNAS is a second one. It is faster, and can be set up to automatically mirror the other (via rsync) on a scheduled basis. It took me three years to get to that point and I would not want to go back.
Message 5 of 5
