Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Volume Dead or Inactive
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-08-29
06:20 AM
2019-08-29
06:20 AM
Hi,
Is there anyway to recover a dead or inactive volume due to corrupt node erros on /dev/md126.
System has 6 x 2TB WD Red HDDs and this happened after a forced reboot.
I've tried "btrfs rescue chunk-recover" but that ended with error.
From dmesg:
[ 324.835517] BTRFS critical (device md126): corrupt node: root=1 block=6247449264128 slot=432, unaligned pointer, have 1441714830712835328 should be aligned to 4096 [ 324.870326] BTRFS critical (device md126): corrupt node: root=1 block=6247449264128 slot=432, unaligned pointer, have 1441714830712835328 should be aligned to 4096 [ 324.870712] BTRFS critical (device md126): corrupt node: root=1 block=6247449264128 slot=432, unaligned pointer, have 1441714830712835328 should be aligned to 4096 [ 324.881576] BTRFS critical (device md126): corrupt node: root=1 block=6247447953408 slot=432, unaligned pointer, have 1441714830712835328 should be aligned to 4096 [ 324.881953] BTRFS critical (device md126): corrupt node: root=1 block=6247447953408 slot=432, unaligned pointer, have 1441714830712835328 should be aligned to 4096 [ 324.938804] BTRFS critical (device md126): corrupt node: root=1 block=6247445889024 slot=432, unaligned pointer, have 1441714830712835328 should be aligned to 4096 [ 324.939251] BTRFS critical (device md126): corrupt node: root=1 block=6247445889024 slot=432, unaligned pointer, have 1441714830712835328 should be aligned to 4096 [ 324.942817] BTRFS critical (device md126): corrupt node: root=1 block=6247445299200 slot=432, unaligned pointer, have 1441714830712835328 should be aligned to 4096 [ 324.943198] BTRFS critical (device md126): corrupt node: root=1 block=6247445299200 slot=432, unaligned pointer, have 1441714830712835328 should be aligned to 4096 [ 324.954048] BTRFS error (device md126): open_ctree failed
Thanks in advance.
Model: RNDP6000-200 (ReadyNAS Pro 6)|ReadyNAS® Pro 6 System Diskless|EOL
Message 1 of 1
