- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Volume Sync stops
- Mark as New
- Bookmark
- Subscribe
- Permalink
Volume Sync stops
I've got an old ReadyNas Duo that has stopped responding. The only way to restart it is by unplugging the power cord. After reboot, it does the quota check procedure, and goes up to 6% of the volume resync and then it hangs.
Question: Should I remove one of the disks and reboot again? Reinstall the OS?
Any help would be greatly appreciated.
This is the information that I captured after the last reboot:
Hostname: nas-5E-2C-3C
Model: ReadyNAS Duo [X-RAID]
Serial: 24M3027T007A8
Firmware: RAIDiator 4.1.14 [1.00a043]
Memory: 256 MB [2.5-3-3-7]
IPv4 address:: 192.168.1.78
Volume C: Online, X-RAID, 2 disks, 98% of 1853 GB used
SMART Information for Disk 1
Model: WDC WD20EARS-00MVWB0
Serial: WD-WMAZA0379771
Firmware: 50.0AB50
SMART Attribute
Raw Read Error Rate 160
Spin Up Time 5300
Start Stop Count 76
Reallocated Sector Count 0
Seek Error Rate 0
Power On Hours 48945
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 74
Power-Off Retract Count 73
Load Cycle Count 1414098
Temperature Celsius 41
Reallocated Event Count 0
Current Pending Sector 1455
Offline Uncorrectable 28
UDMA CRC Error Count 0
Multi Zone Error Rate 2878
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 4665
Power glitches 0
Hard disk resets 5
Retries 5
Repaired sectors 0
SMART Information for Disk 2
Serial: WD-WCAZA9808944
Firmware: 51.0AB51
SMART Attribute
Raw Read Error Rate 0
Spin Up Time 4975
Start Stop Count 7072
Seek Error Rate 0
Power On Hours 35950
Spin Retry Count 0
Power Cycle Count 66
Power-Off Retract Count 55
Load Cycle Count 114672
Current Pending Sector 3
Offline Uncorrectable 0
Multi Zone Error Rate 8
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 6
Power glitches 0
Hard disk resets 5
Retries 0
Repaired sectors 0
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Volume Sync stops
I believe that is a good plan, and you should do it with Drive 2. The high pending sector count, raw read errors, and other errors suggest Drive 1 is failing. Assuming that works, backup your data, then replace Drive 1 with a suitable (not Green) drive. And be prepared to replace drive 2 before long as well. It does not have nearly as many load cycles as the other (likely because of the newer firmware version), but it does already have some pending sectors.
- Mark as New
- Bookmark
- Subscribe
- Permalink
WD20EFRX are good replacements for the old WDC green drives you are using. They are intended for NAS use, and work well in ReadyNAS Duo v1s.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, I removed disk 1. Trying to backup the share but it is not even starting the backup as there is some sort of problem with the connection (backup log message below)
rsync is enabled on my unit. What should be my next step here? I am reluctant to reinstall the OS as I don't have a backup of this data (I know, shame on me). Thx!
Backup Status: Fail: Failure during copy.
Failed to run rsync, return rc 10
'rsync' command returns rc=10
rsync: failed to connect to 192.168.1.78 (192.168.1.78): Connection refused (111)
rsync error: error in socket IO (code 10) at clientserver.c(125) [Receiver=3.1.2]
- Mark as New
- Bookmark
- Subscribe
- Permalink
Forgot to mention that when creating the backup job, it did require a port number (I put 6000 as I didn't find any reference that a specific port number should be used). I wonder if that is my problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was thinking maybe I should get a USB disk and do a local backup instead of ReadyNAS to ReadyNAS. Thoughts?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bought the USB drive. Back up is working but it is going to take days to complete...
- Mark as New
- Bookmark
- Subscribe
- Permalink
The standard port for rsync is 873. Unless the rsync server to which you are sending the data uses a non-standard port, that's the one you need to use.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thx for the info. I should have made a simple search for "Standard rsync port". Duh! Anyway. Will let the bakcup to the USB drive finish and retry using rsync to my other ReadyNas duo.
Do you think I should insert the new HDD (not arrived yet) as is or try to reinstall the OS first?
Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update:
USB Drive backup completed but... Going back to the log, it says there were errors. I tried to download the full system log and the zip file is corrupted.
Just waiting for the new disks (bought the red ones as per recommendation) to arrive and start the replacement process.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Make sure the rsync backup job is set to incremental, and then try running it again. It should complete quickly (only trying to copy files that weren't transfered the first time).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update:
Got the new disk (WD Red) as recommended. Replaced disk 1, resync went fine. Status is healthy on both SMART+ reports on the bottom).
But...
Ran backup on USB drive and it gave me a bunch of "cp: cannot stat Input/output error". Any ideas as to why the backup is still failing? Any workarounds?
Thank you!
Model: | WDC WD20EFRX-68EUZN0 |
Serial: | WD-WCC4M3NCRNZ1 |
Firmware: | 82.00A82 |
SMART Attribute | |
Raw Read Error Rate | 0 |
Spin Up Time | 0 |
Start Stop Count | 1 |
Reallocated Sector Count | 0 |
Seek Error Rate | 0 |
Power On Hours | 11 |
Spin Retry Count | 0 |
Calibration Retry Count | 0 |
Power Cycle Count | 1 |
Power-Off Retract Count | 0 |
Load Cycle Count | 6 |
Temperature Celsius | 37 |
Reallocated Event Count | 0 |
Current Pending Sector | 0 |
Offline Uncorrectable | 0 |
UDMA CRC Error Count | 0 |
Multi Zone Error Rate | 0 |
ATA Error Count | 0 |
Extended Attribute | |
Hot-add events | 0 |
Hot-remove events | 0 |
Lp stat events | 13 |
Power glitches | 0 |
Hard disk resets | 0 |
Retries | 0 |
Repaired sectors | 0 |
Model: | WDC WD20EARS-00MVWB0 |
Serial: | WD-WCAZA9808944 |
Firmware: | 51.0AB51 |
SMART Attribute | |
Spin Up Time | 6366 |
Start Stop Count | 7076 |
Power On Hours | 36139 |
Power Cycle Count | 70 |
Power-Off Retract Count | 59 |
Load Cycle Count | 114672 |
Temperature Celsius | 38 |
Current Pending Sector | 3 |
Multi Zone Error Rate | 12 |
Lp stat events | 4 |
Retries | 0 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
How is the USB drive formatted? How big is the USB drive? A duo V1 can't handle a USB drive bigger than 2 TB.
If it is a format windows supports, try putting the USB drive into a Windows PC. It likely will offer to "repair" the file system - if it does that, let it.
FWIW, USB backup on a duo v1 is extremely slow. You will get faster speeds if you connect the drive to a PC and back up over a wired Network. If you do it that way, you can use something like FreeFileSync or Teracopy, you don't need to use the built-in backup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is important to mention that the USB drive is there to back up the NAS data which came from old laptops that are now in computer heaven. I am doing current back-up on the cloud.
How is the USB drive formatted? EXT3
How big is the USB drive? 2TB (it is 1.8GB occupied)
From what I've seen on a different thread, I would need to install drivers for my Windows PC to be able to read/write on the EXT3 formatted drive. Having said that, I tend to believe that the repair would be required on the NAS disk and not on the USB drive. Am I wrong?
FWIW, USB backup on a duo v1 is extremely slow. I painfully noticed that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OSX and Windows are quite forgiving on USB drive ejection. Linux isn't, so if the drive is pulled without being ejected (or even if the system is forcibly shut down with the drive mounted), the system tends to mount the drive as read-only.
Since it is ext formatted, Windows can't fix that.
Usually it's the USB. The details in the log might be useful in sorting it out, you can also try resetting the file permissions for each share in the "advanced" tab of the share settings. If you click on the icon for any supported protocol on the share list, you'll see the advanced tab on the right.
If you aren't far along, perhaps reformat the disk as NTFS (assuming you use windows), and start the backup again over the network (using freefilesync or teracopy). It should be 3-5x faster (about 3x if you use 100 mbit ethernet). That should also give you quicker information on the problem files if it were to fail. Teracopy can verify too, I don't know if freefilesync has that feature.
